Power steps on '22 malfunctioning
BrokerThis
'22 Denali Dmax
Detroit
Anybody running into a similar issue with the cold weather?
Started off 2 days ago with my driver side staying down when parking the car. It would attempt to retract to the up position but wouldn't complete the cycle and end up down. While starting to drive, I could hear it cycle a couple times and it would finally end up in the up position. I removed as much snow/ice build up as possible from the step.
This morning, while taking my 45 minute drive to work, I could hear it cycling up and down while driving several times. Confirmed it was the steps I was hearing as I was able to look down out the window to see the steps going up and down while I was slowly driving. Then when exiting the car, the step didn't come down but seems to not be fully up in place.
I'm thinking there might just be some ice/snow buildup somewhere causing an issue to malfunction like this, but we got another 5 days of bitter cold before anything will thaw out. Anybody have experience?
Stbentoak
Try to find a car wash in your town that has indoor facilities that you can go in in a protected atmosphere and blast them off including all the joints pretty well. Within 15 or 20 minutes or so you’ll know whether that’s the issue or not….. these things don’t like build up. Winter Sucks…
olyelr
Elk Rapids, MI
Yea, sounds like its more than likely just snow/ice buildup. If you guys got anything like we did (im several hours north), im sure there is a bunch of crap stuffed all up under there. Parking it indoors for the night and letting everything melt off would pretty much tell you if thats your issue.
BrokerThis
BrokerThis
'22 Denali Dmax
Detroit
I'll probably have to do that tomorrow and kick the wife's car outta the garage for the night since her spot is filled with all the outdoor Xmas decorations that still need to be put away hahaha. Hopefully doing that won't put me into the doghouse
WalleyeMikeIII
Sunny and Snowy Minnesota
It won’t if you wake up early and start her car her so it’s nice and warm when she leaves!
WalleyeMikeIII
Also, do you have any mud flaps on? I put the weathertech no drills on, because otherwise the boards behind the front wheel just take too much junk in the winter.
olyelr
Elk Rapids, MI
For what its worth, we drove my wifes last denali for 125k miles in northern michigan and never even once did we ever have an issue with them not working or malfunctioning. But i do know its a fairly common issue when in snowy climates. Think about it…they have a failsafe built in that senses pressure so they dont pinch a foot or something else and cause damage. Dosnt take much snow buildup to start causing issues.
Vladimir2306
I'm tired of struggling with these steps. I ordered myself the usual fixed
BrokerThis
BrokerThis
'22 Denali Dmax
Detroit
Yep, bought em when the rig was actually being built and had em on hand when taking possessio of it. they do a pretty decent job
dusttur
I have a 22 Yukon AT4 and live on a dirt road. When it rains the road gets really muddy and all that mud gets all over the retractable steps. I have once experienced the same thing that you described so when I got home I washed the mud off the steps, specifically the actuators, and it fixed the problem.
Vladimir2306
As I said above, the steps do not want to work in snow and mud conditions. I'm tired of driving with the steps disabled. And I bought myself fixed ones. Finally, I’m happy that I have rapids in winter, and I don’t have to jump into a tall car)
Punteh
I had to turn mine off. The whole area has to be basically snow free to get them to go up. After every drive I'd have to take a snow brush and clean the running boards, rockers, and brackets of snow completely. Doing that after every drive obviously isn't very practical for the entire winter. So they're off for now
BadDaddy2003
