Power steering whine
Mid_length
Hi all, I recently bought a 2007 suburban 1500 4wd. The power steering pump whines. I’ve changed the fluid twice the second time with synthetic. Still whining. I’ll change the pump if that’s what it comes to but I thought I’d ask first. Thanks!
Probably time for a new pump. Don't get a reman, they whine too usually!
M
Mid_length
I read somewhere that clocking the wheel with the cap off would work the air out. How should I bleed it?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Initially you should have bled the fluid with wheels off the ground and engine not running. Fill fluid and turn slowly, lock to lock and watch as air bubbles rise and dissipate at the top. Then start the engine and lock to lock some more and add fluid as needed. Then drop to ground and repeat the engine running and lock to lock and add as needed. Recheck after the first 2-3 drives.
Welcome to the forum.
Like @swathdiver said, new, not reman, pump.
Just Fishing
Can't fix stupid
Utah
i flushed the ps fluid in my wife's car, got some air in there by accident while i was doing the lock to lock with the return line sitting in a drain pan.
I got some pretty good whine after.
She ended up driving it for two days and the sound went away.
Now if you did the flush trying to fix it, and it's still there.
Then it may be the pump itself.
JasonW4141
