Power Steering Pain
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Here's the DIY video I referenced earlier:
Replacing the rack is a very manageable repair for a diyer with the front on ramps or jack stands. I bought a rebuilt Vision OE rack for just under $300. It's recommended to replace your lines but if you're on a budget, start with the rack and perform a thorough fluid flush. If you keep your old lines, you'll need to buy a pack of cap seals to reinstall the line into the new rack.
Look at the stuff running out of that cross member when he hits it with the impact, LMAO!!!
89Suburban
SE PA
My rack is overdue for replacement.
solli5pack
Yes, I replaced it and I would rate it as a pretty easy repair for anyone with reasonable mechanical skills. I was replacing the oil pan gasket which required dropping the front differential and unbolting the rack from the frame so I was already in there. There is good access and room under the front with the truck on stands and the forward plastic shield/skid plate off. The procedure is pretty straightforward: disconnect the outer tie rods (which may be a little frozen or rusty), disconnect your fluid lines, disconnect lower steering shaft and unbolt from the frame. To make sure you install with a centered steering wheel, count the number of rotations from full stop to full stop, divide in half and turn that many rotations to get the rack in a straight forward position. Lock your steering wheel with the seat belt looped through to ensure it doesn't move during the repair.
I bought new pressure and return lines which is recommended to avoid contaminating the new rack. It's recommended that you get an alignment afterwards but you can mark your inner tie rod nut and get the new rack on pretty close to the same position, assuming it was aligned when you started. Fill up the fluid, bleed the system, and your set.
Did you vacuum bleed the system after the install or just turned the wheels back and forth to the stops burping out air? I just installed a new rack and lines and I just burped it turning the wheels back and forth with the ps pump cap off. So far everything great l, no leaks or noises but the steering turns real easy. I'm not sure if this is normal compared to my old rack or maybe some air trapped in the system.
blondie70
With my new rack installed....the steering was much easier. It was good before but got better.
solli5pack
The steering is definitely much easier with the new rack installed to the point that it feels a little loose. But that could be my mind playing trucks on me compared to the old rack. I changed all the hoses and drained the pump so I'm a little worried I might have some air trapped in the system. Planning on renting a vacuum pump and see if I can pull some out.
alvocado
Allen
Cincinnati, OH
I have always bled the PS system by turning the steering wheel lock to lock about 20 times with the wheels off the ground and it has worked every time. Symptoms of air in the system would be whining noise or stiff steering, not loose steering.
Bronson357
Its to the point where now im suddenly not losing fluid but its as if I dont have power steering in certain slow parking lot turns. I gotta decide to keep this thing or not (its real beat up looking and takes in water, was in 2 wrecks, was decomissioned and probably maintained horribly) I got it for 5K a few years back at like 130K miles, and its been one thing after another pretty rapidly since. I only put 20K miles on it.
Any idea what a shop would charge for a rack install?
I know stupid but have you checked tire pressure? If mine gets low it doesn't like to turn at idle
Tupapi
