Power steering pump question
Tbruz
Windham NH
Greetings.
2 PS pump questions:
Can the hydroboost PS pump be used on a truck that does not (as yet) have hydroboost if you block off the extra return/flow tube.
I need to replace my PS pump on my non hydroboost truck but am thinking I want to add hydroboost at a later date and would like to save a pump swap.
Does the hydroboost pump flow more fluid/rate than the non hydroboost version?
I'm thinking the pump is the same and only the body/reservoir is different?
Thanks
Tbruz
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes that work just fine, as long as you match the pump to booster in years and gvwr you should be fine.
---------- Post added at 06:29 PM ---------- Previous post was at 06:28 PM ----------
so like in rpo codes all jd5 components or or all jd6 components for example.
Drewphil
