Power door locks stopped working...
Swapped the fuses around, still no action.
not the fuses, relays, usually they are black or grey with a number printed on the top and are rectangular shaped, they can be a little hard to wiggle out
they look like the black ones in this picture
vishnu619
vishnu619
This is what fuse box on the drivers side looks like. The 30 amps at the top left control the door and the drivers seat. Everything else on the door works just not the door locks. I swapped them anyway and got the same results.bf469472123200530358a2ac17a849fb.jpg
maybe there inside the fuse box under the hood then, they changed everything in 2015 but the GM upfitter diagram still shows both the front doors are on the same circuit.
dbbd1
Check the passengers side fuse box too.
vishnu619
vishnu619
Well everyone turns out none of the fuses were bad, it was the actuators today. It was not that bad. Here are a few pics of the process to rebuild them with better motors from www.gruvenparts.com
You have to take the foam piece on the door and a brace that runs over it.fa5048a961ba0a8dadcc89b6aa0c1721.jpg869c8dbd1eb6af18bf3cd2af1e4b64e9.jpg67b7141ef94aeee6644e8b0ceb145a57.jpg7a4063b32759e2e0532a068faa1998f6.jpg7f5dfdbbb237751641f0754d5345f94d.jpgba24e1f0c1179bcdf1c77075a5916379.jpg362e36b039a729d53676e1b7eb6453cb.jpg63eaf94e551c7245df53a463aef61f9a.jpgf787d5cdcc52223695f4076abca996f0.jpg
rick9667
