Post your lifts.
liftedtahoe
arkansas
what size wheels are those 35s sitting on and do you get rubbing?
Mines on 17s and not much rubbing unless I put it in a pretty good bind while I'm turning!
Sent from my SAMSUNG-SM-N910A using Tapatalk
DarkBlueHoe95
West Columbia, SC
Supreme suspensions lift keys. Passenger side 04 torsion bar on my drivers side. Cranked a good bit on Yukon 17s and low tread Toyo 35s
Does not rub on fender or bumper/valance. Rubs on little metal bracket at full lock. Also rubs on rear shock bolt when rear cycles completely.
My Dark Blue Hoe
liftedtahoe
arkansas
whats the width on those? im runnin 8 wide and seeing if i can get a 12.5 on them
Mine are 7.5 wide and I'm running 35-12.50s but I'm running 2" wheels spacers to keep it out of the rear trac bars
Adirk
Grand Rapids
so my 8s should be fine, they already have some backspacing, couldnt tell you off the top of my head but the ol tires jut out like 1.5-2in
liftedtahoe
arkansas
Yea you should be fine then buddy! My mud grapplers have the side lugs or I could have ran my factory offset but you should be alright!
Adirk
Grand Rapids
thanks mate, time to go shopping for 33s
hoe
Need to get new pics but here is the gist
Here is the rear
That's clearance you want to fit 35s!
These are all old pics. Will get some new pics tmrw as the stance was adjusted and changed as well as track width in front.
I have 9" of lift with stock keys. 6" lift with 3" spindles up front. In pics it's way de crunk! To be more like 6".
Currently they are cranked like stock for ride quality. So the front is higher. Going to replace my 1.5 in spacer in the rear with either 2.5 or 3 and crank the keys or put in my lift keys. Riding decrunk is just too soft a ride. Lol
liftedtahoe
arkansas
Here is the rear
What size lift you got?
hoe
6" super lift up front with 3" lift spindles. Pretty much decrunk stock keys all the way out till I lift the rear. Pro comp 4" kit with 1.5" rear spacer. Going to go with a 3" Spacer and level the front to match. So overall it should be set at 7-8" lift when done!
liftedtahoe
arkansas
You can fit bigger than 35s under there! Right?
liftedtahoe
arkansas
Cuz I have 35s on mine and not near that much lift
hoe
Yes you can! I just hate the stuffed look. But I'm pretty sure I can fit 37s. I'm sticking with my 35s though for full articulation. I also don't have any body lift so tires can get close to the body with extreme off roading. I have 0 rubbing and have done major triming as well.
liftedtahoe
arkansas
Yes you can! I just hate the stuffed look. But I'm pretty sure I can fit 37s. I'm sticking with my 35s though for full articulation. I also don't have any body lift so tires can get close to the body with extreme off roading. I have 0 rubbing and have done major trimingb as well.
Tuechè [emoji106]
Antonio Estrada
Fort Worth Tx
Hey im looking to lift my denali in the front more i have ready lift 3in torsion keys cranked all the way my front shocks are worn out and since they are finally out i wanna go to 6in lift just up front an thoughts on what i can do or buy to get those 6inches up front ? Id appreciate the response thanks in advance.
Antonio Estrada
Fort Worth Tx
liftedtahoe
arkansas
Hey im looking to lift my denali in the front more i have ready lift 3in torsion keys cranked all the way my front shocks are worn out and since they are finally out i wanna go to 6in lift just up front an thoughts on what i can do or buy to get those 6inches up front ? Id appreciate the response thanks in advance. View attachment 59735
Awd?
Ossipeelake
