Possible brake issue...
9HOE9
I recently purchased an 04 Tahoe LS 2wd and drove fine first 2 days then starting making a slight grinding noise, off and on randomly which has gotten a little worse starting to make more noise...
I thought the noise was coming g from. Rear passenger tire, I was thinking it might be the parking brake failed (parking brake doesn't work at all)
So I pulled tire and rotor and caliper and hub to check the shoe and brackets and shoe seemed a little loose. Put it back together and noise it still there but now sounds like it's on the driver's side... Area
I'll try and post video of the sound.. as well as pictures of passenger rear parking brake show
Here's link to video of the sound
https://goo.gl/photos/YkwZHFdd6buzdZaPA
Sent from my LG-LS993 using Tapatalk
HiHoeSilver
Away!
Chicago
Are you sure it's not the hub(s)? Is there any play in the wheel top to bottom?
9HOE9
Found the problem... It was the Parking break shoe on the driver's side... Looks like it disintegrated leaving no pad on the shoe... And just left pieces to roll around and make weird sounds
Ran to AutoZone and got a shoe kit and hardware and changed both sides... Still need to adjust parking break.. doesn't seem to be working
BrentL9900
