Passenger front window not working
George Owens
OK my passenger side window doesn’t seem to work. I know the motor is good because I’m able to move it up and down when I bypassed from the battery to the motor directly. I don’t know if there’s a fuse for the passenger front side switch or where to find it none of the fuse panel say anything that indicates that for sure. Pretty much when I try to roll it down it only clicks. I’m not sure if I need a new window switch or not but some help would be appreciated to point me in the right direction.
intheburbs
SE MI
It's a known issue that the switches are susceptible to moisture ingress. Things like going to a drive thru in the rain, getting water on the switch, cause problems.
Most commonly, it's the driver's side switch. Pop it out, clean contacts as needed.
George Owens
George Owens
Does the passenger window work from drivers side switch? check for power to the inoperative switch, up and down.
No the driver side switch won’t get it to move either, this all happened because I hit a wire where ya feet go when pressing the ebrake…I have fixed the wire and don’t see any broken wires down there so I’m lost
George Owens
George Owens
I thought that too, I used a replacement switch before and that didn’t do anything. Only switch I didn’t try yet is the passenger side itself but I wanna get more views before I order one
exp500
Switch signals relays- test signal out of switch to relays- all 3.
George Owens
George Owens
I thought that too, I used a replacement switch before and that didn’t do anything. Only switch I didn’t try yet is the driver side itself but I wanna get more views before I order one
Passenger side switch I
care to elaborate a little more? Like where to find them
exp500
My mistake- was the door lock relays I had in my mind. Maybe this will help some.
George Owens
George Owens
I would start pulling panels George and look for more bad wires. Live near anyone with a Tech-2, that can help diagnose the problem too. I suspect it has something to do with where your boot hit!
George Owens
George Owens
I hope not, diggin for wires is a pain, my gut is telling me it’s the switch just need to find a junkyard with a compatible part
BadDaddy2003
