Paint touch ups and rust repair
tungsten
tungsten
So some research suggests dont bother spraying clear,either a hand wipe like @Tonyrodz says or just keep adding wax and re sand again every year.
tungsten
tungsten
I did start at 220 dry grit in one spot to see if I could make perfect,took a lot of 320 dry and 400 wet to remove scratches but I was able to make it look good.
tungsten
tungsten
Thanksgiving up here in Canada. Golfed today so getting behind on my project. Sanding the inside of fuel door had some gaps so filled with bondo. 05CAB6A9-D872-4F33-8B3D-EA21A0F4EC70.jpeg
tungsten
tungsten
What did your research find out about spraying clear on the headlights? Turns yellow quick?
Possible crackling also like a spider web.Also that re sanding in the future would be very difficult.
Makes sense. When I did headlight restoration for my business I'd give a 1 yr warranty against yellowing or clouding--never got a complaint, and I did it for 9 yrs.
992dr
N.C.
Everything is lookin good. Nicely done T
Like the name, Tungsten. You a welder?
tungsten
tungsten
No. I fly fish and all my flies I tie have a tungsten bead on them so they sink faster. Cheers
tungsten
tungsten
Finished sanding and got some primer on. Still need a little spot putty but not too bad. 108AFF0D-6452-41FD-A838-69284CCEBD58.jpeg95FE8525-D57E-4404-A661-82A9B8FEE73B.jpegThink I’ll move to the other side. Haven’t had time to make it to the paint shop to try and match better. Dam work gets in the way.
Mazer16
