p0449 back again
Most Hated
Awhile back I got the p0449 code on my 07 tahoe. I replaced the vent solenoid and cleared the code. It immediately came back. I ended up taking it to the dealer. They found a broken and corroded wire and repaired it. The code went away. However, a couple days ago the light turned back on. P0449 again. I pulled my receipt from the dealer and in the notes section the technician said the repair was made in the #1310 circuit at the C300 connector located at the left side underbody. I found a little info about the connector stating that it was located in front of the fuel tank near the brake module. I think I found the connector but was wondering if anyone else had any info on this connector or a picture of it. Also, does anyone know the wire colors for the vent solenoid at this connector or the pin numbers on the deutch connector? Thanks
jz57
When P0449 comes on, you should replace both vent valve and purge valve.
M
Most Hated
Its not the vent solenoid or purge solenoid. They both checked out fine, There was a short in the negative wire from the ECM to the c300 connector. Repaired the short and light is off.
veteran111
