P0175
03GMCYukonXL
Replaced my lifters and now getting a P0175 code. As a side note, I also replaced the purge valve and charcoal canister at the same time as well as coil packs and injectors. I'm not sure if anything I have done would have caused this or if its just one of those things where if you fix one thing another breaks.
Probably worth mentioning, but I broke the bolts off of the y pipe so my exhaust now ends where the y pipe ends. I couldn't get the studs out. I'm wondering if that's affecting the 02 sensor and throwing this code?
I am not getting a P0172 code. Only P0175
Geotrash
Dave
Richmond, VA
If the exhaust leak is before the downstream o2 sensor, then yes, that's a potential problem in this case.
You could also get the code for a while after replacing the purge valve if there were any fuel vapors in the lines that were trapped in there. With a working purge valve, that unburned fuel is gonna get sucked in.
03GMCYukonXL
If anyone is curious....yes my exhaust ending after the y pipe WAS the issue. Got determined today and got the broken studs out and put my exhaust back together minus the muffler. Drove fine, Idled fine, No CEL.
Edit, I have only 2 cats. So all the 02 sensors were connected and both cats were present. I have no idea why that caused a bank 2 rich condition.
03GMCYukonXL
Actually may have jumped the gun. It's ran fine for 2 days now and all of a sudden I get the service stabilitrak but no CEL. Scan it and it's pulling the same P0175 code.....
ivin74
05 NBS Nali
Htown, Texas
Did you install oem parts or aftermarket?
ivin74
05 NBS Nali
Htown, Texas
Please check the items listed below.
I'm willing to bet you have a bad injector, specially if it's not oem.
*Fuel pressure, you are running to rich
*Inspect the fuel injectors for leaks
*Inspects all vacuum lines for cracks and deterioration(pvc line)
* Do a leak test on the intake manifold. Did you install a new intake manifold gasket?
*Inspect the oxygen sensors (Did you unplug these sensors?)
TVSS
