Opinions on Potential Denali Mods ...
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Sure, you'd ask this on a day I wasn't working. As for the bulb itself, it's a fairly uncommon one that I doubt anybody stocks. It came up as a special order part for me at work, so now I carry them.
It seems that GM is on this kick about using bulbs that nobody has. I got a call the other day for a 3rd brake light bulb on a 2005 Pontiac G6. No info in my computer. I managed to get my hands on it for a part number. I learned a few thinks that day. Wagner its the OE bulb supplier for GM. GM is making them put all the bulbs in plastic clips. And, the bulb was not available for Wagner vendors, which my company is. Not even the GM dealer nearby had it.
Sent from my myTouch_4G_Slide using Tapatalk
soulsea
soulsea
Bar
Hi Connor,
Actually I'm not looking for anything related to bulbs ... what I'm trying to get is the actual fog lamp housing measurement to see which size aftermarket fog lamp housings are a direct replacement.
To be more exact ... i'm looking at this as a replacement: http://www.rallylights.com/detail.aspx?ID=128 but I'm not sure it is big enough at 90mm. But that's because I measured mine at the edge of the lenses. So it may actually be the same fitment but I'm measuring at the wrong spot.
Does that make sense?
05Yukon23
Arkdelphia, AR
Maybe you should just remove the current housing and measure the actual hole it mounts into. Shouldn't be too much involved, right?
soulsea
soulsea
Bar
No, I can't imagine it's too difficult ... but no reason to do so until I know exactly where to measure, and I don't know that the bumper opening size is in fact the corresponding standardized measurement to lamps. I mean it might be, but it'd be nice to know for sure so i only do it once.
soulsea
soulsea
Bar
Okay, so this is why we don't go around measuring stuff randomly ,,,
This 90mm hella fog lamp has the spec drawings with it. http://www.rallylights.com/detail.aspx?ID=132
So 90mm refers to the overall depth of the lamp and not the width.
So it seems that I need to take my lamp out after all, measure the gap in the bumper, and find a replacement lamp that lists its specs like this one to see if it will fit through it.
What a pita.
---------- Post added at 11:51 AM ---------- Previous post was at 11:48 AM ----------
This is what our fog lamps look like:
Stupid conical shape is what makes me have to remove it to measure. Ugh!
THE YETI
Director of Operations
South FL
Serge, a stock fog lamp takes all of about 12 seconds to remove. Just don't fall alseep under your truck again....
edgaranah1
Corona California
Haha
Yeah serge the fog light just pops out. Less than 15 seconds to do.
Sent from my BlackBerry 8530 using Tapatalk
soulsea
soulsea
Bar
Alright alright I'l do it ... later tho, it's -769F out there right now.
THE YETI
South FL
no heated garage? jk...
I just came back from Charlotte, NC and holy CRAAPPP was it cold and windy last night!!! :freezingtesticlesoff:
I don't blame ya for staying in today old timer'
Timmy
Brunswick, GA
it was 24* when i got in the tahoe at 630 this morning.
It was 11* here this morning...
soulsea
soulsea
Bar
Does anyone know if unplugging the power assist step harness throws out a code on the display?
I know when you deactivate the blind zone alert it reminds you all the time.
soulsea
soulsea
Bar
Can I ask why u would do that?
Cause I may take them off to have stuff done to them and I want to know if doing so is going to show up on my dash.
---------- Post added at 10:30 PM ---------- Previous post was at 10:30 PM ----------
Is there an indicator light for it? If not, I don't think you need to worry about it.
There is an option on the DIC to temporarily deactivate them.
canadiandux
