Ole 2 Speed
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Don't forget to lightly scotch bright the surfaces the sprag bearings, piston seals and pump rotor/veins run on. Helps reduce friction by allowing trans fluid to build on the surface. That "precisions transmissions" guy I have watched a hundred videos on harps on this a lot. "Scotch bright is your friend", literally says it in every video. Good luck and post some pics!
That's a great suggestion to remember, I will be following along with his videos as I attempt this tonight. I still haven't gotten @iamdub pump yet so we plan to use the one out of the trans thats in the Tahoe now. I'm still totally down to trade whenever you get yours pulled apart.
pwtr02ss
Tennessee
Did you take it down any further? Disassembly wise
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Didn't touch the tranny.... usually I can't say that.
Did find some grundle butter in the valley cover knock sensor holes, yummy. :p
The knock sensors harness hasnt even attached anymore, the entire plastic clip had turned to dust.
Dub can't pause the **** ******** the Universe has dealt him long enough to handle business. :nono:
johnsonwillie199
