Oil separator canister
greenhornet
Ontario,Canada
Where is the separator canister lines hooked into on the engine and what size are the lines.2015 Tahoe LS 5.3. Thanks.
Basically, the oil catch can is inserted into the line that runs from the PCV valve (at the rear of the driver's side valve cover on my 07 Yukon XL Denali) to the intake manifold. Many oil catch cans include the catch can mounting hardware and lines that you need, and you simply remove the existing line between the PCV valve and the intake manifold, and replace it with the supplied lines. Costs for oil catch cans can run between $30 and $160, and the reality is that there is not too much difference between them.
The discussion thread below has a lot of detailed information on oil catch cans and their installation. After reviewing this thread, let us know if you have any further questions.
https://www.tahoeyukonforum.com/threads/finally-jumped-on-the-oil-catch-can-bandwagon.125572/
mfinta
