DonnieBrasco
- Joined
- Sep 11, 2012
- Posts
- 114
- Reaction score
- 5
2003 Yukon with ~215K miles. Never noticed any issues or fluctuations with my oil pressure. Right after cranking up it bumps up to dead center at 40 and holds there. This weekend I started noticing some fluctuation. Now, I was overdue for an oil change. Not extremely overdue, but it had been around 7k since my last change. As soon as I got back in town yesterday I changed the oil. The pressure fluctuation is minor. When I am idling it drops just below 40. When the RPMs go up on acceleration, it bumps up a little over 40, but it never goes over ~60. If I'm cruising around 70-75 mph, the oil pressure stays around 55 or so.
Also, when I climbed under last night to change the oil, I noticed around the drain plug and all around the oil pan was pretty oily. I haven't noticed that much oil build up before. So it's possible I have a minor leak? I never notice oil under the car after sitting overnight or in the garage at work. Maybe a drop or two, but nothing significant.
1. Is oil pressure fluctuation as described above an emergency situation or should I just watch it and see if it gets worse?
2. What could some of the issues be? I was wondering if it was sludge buildup at the intake on the oil pump.
I probably have a year or less left in this Yukon, i.e., I don't want to do a ton of maintenance ($$$) if I'm just going to get rid of it later this year. I just want to keep it able to get me from point A to point B until I'm ready to get a newer one. Thanks for any advice.
