Oil pressure drops as it warms up?
Big Roller
Tennessee
I bought a 99 tahoe from a local mechanic with 260,000 miles on it for 1,500 bucks... Had a blown head gasket. He fixed it and I've had no other problems with it... Until recently. On cold starts, the oil pressure goes up to 60-65 psi. But as it gets warm and gets up to operating temp, the oil pressure slowly starts going down... After 20-30 minutes of driving, it will sit around 20 psi at 1500 rpms, but will drop below 10 psi at idle? The pressure also goes up as rpms increase. I've read so many different threads on here that I don't know where to start looking. :throw: Has anyone else had this problem before? Any help is much appreciated!!
ezdaar
Chat Troll
Redneck central, Aka Houston
Negative. anything below 20psi is bad! You should be around 40 at idle.
I would not be driving that tahoe on such low oil pressure.
Pour a can of seafoam in the oil fil and baby it for 2-3 days of driving, be warned of potential oil leaks.
Then change oil filter and oil asap! Heck the filters are cheap enough, change it before and after the seafoam treatment.
ACdelco PF48 (GM break in filter) or PF63 (GM replacement after break in).
These are OEM replacements and have the larger oil passage holes but are identical other than length.
Switching to this Always brings the oil pressure up, sometimes substantially vs other brands.
Example. Just did a oil and filter change on a friends truck. he had 19-21 psi at idle.
Changed to mobile 1 10-30 from what ever he had in it and from some pos fram filter to the PF48 he now has 41PSI at idle.
If doing the above doesn't help. you have a oil pump failure coming.
B
Big Roller
Tennessee
Oh boy... I'll definitely try the delco filter. I changed the oil about a month ago, and that's when the problem started. I just used a purolator filter(used to work at Sears auto, and that's all they carried), and assumed that would be okay. I get paid Friday so it has to wait until then.
B
Big Roller
Tennessee
5.7. I used 10w30 when I changed it last, and I don't know what the previous owner ran in it. Should I bump up to 10w40?
TraumaTruck1
Decatur, AL
Purolators can are known to be restrictive. That could be your problem. You might could try to get just a filter and a quart or two of oil to top it off.
Did you check to make sure that the oil level isn't low?
mattluttrell
This might be wrong advice, but I've bumped up the weight in old small blocks to get my oil pressure back. I'd go back to 40W and see what happens. I certainly don't see it being a problem in summer. I might go higher if 40W doesn't work. I try to keep all the needles facing up if possible.
B
Big Roller
Tennessee
Oil level is full, so I know that's not the problem. From what everyone's said, I can also rule out the sending unit, correct?
TraumaTruck1
Decatur, AL
I'm not sure what a sending unit does when it goes out, but I wouldn't think so because the pressure is dropping as the oil warms up. I would think a bad sending unit would just show low all of the time.
I would start with changing the filter and topping the oil off.
If that doesn't work I would move up to a higher weight oil. If that does work, your bearings are wearing down. The higher weight oil will probably last a while though. Racing engines and the older engines were built loose. That's why they have a higher weight oil to begin with.
B
Big Roller
Tennessee
Sitting at a red light today, oil pressure dropped to zero... I immediately put it in neutral and revved it up to get oil pressure back up. I'm leaning toward a new oil pump... The truck is my only vehicle so I'm worried about burning the motor up.
I've read about checking bearings or something like that while the oil pan is off -- what am I looking for?
ezdaar
Chat Troll
Melling high volume, high pressure pump. don't install a oem rep.
Make sure you get the Aluminum reinforced one piece oil pan gasket from felpro.
It resists "squishing" along the sides of the oil pan which causes leaks.
And as always, make sure your oil pan gasket surface is straight, smooth and not dented up.
Be sure to clean the block and oil pan gasket surfaces with 90% alcohol.
Good Luck.
Bad bearing
B
Big Roller
Tennessee
Well, running short on funds this week... So I'm just gonna try switching to heavier oil and ACdelco filter along with Lucas Oil Stabilizer... Hoping for the best!
B
Big Roller
Tennessee
Changed the oil to 10w40 and used a quart of Lucas and ACdelco filter, and so far I'm running 20psi at idle and about 50 at 2000rpms... I will never use anything else but ACdelco ever again! We'll see if that fixed the problem... If not, I guess it'll be time for an oil pump.
mattluttrell
That's good. You could even go a little heavier with the oil. I've done that in old 350s.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
changing to a high volume pump will not help a whole lot. ion fact it may leave you with a broken pump shaft or oil starvation in the pan if it keeping most of the oil in the block more then in the pan. and on that if a pump fails then replace it but if your oil pressure is changing with different viscosity then look at you filter or bearings as the issue. would dump the lucas stuff as well it really just thickens the oil.
B
Big Roller
Tennessee
A week later and still no more pressure issues. I really think it was the crappy quality oil filter that caused my oil pressure to drop so low. Running at 60mph on the highway, my oil pressure sits at 40-45psi. Even goes up to 50+ if I jump on it. At idle I'm sitting at 20psi. I think I'm gonna run 10w40 for the rest of its' life. Maybe switch to 30 weight in winter if the 40 doesn't want to flow well.
Drewphil
