odd stumble when accelerating
RLC2020
I've owned my 2015 Yukon for about a month now and after about 1200 miles I've had a nagging issue with it that I'm hoping to get some suggestions with before I start replacing stuff.
This only happens in the morning on my first drive with it and only happens under certain throttle positions.
The truck will start right up and run fine, it does fine under light acceleration leaving my driveway and driving down my backroads. When I go to pull out onto the very busy main road in town I have to use moderate acceleration, this is where the issue occurs. After the shift into 2nd gear and sometimes after the 3rd gear shift, the engine will fall flat on its face and it will act like it has no power. I have to give it about 80% throttle for it to "snap out of it" and start pulling again. I've tried giving it full throttle and it runs through the gears just fine, it's only at mid/moderate throttle that it happens. The weird thing is that it's fine at idle (other than a slight rough idle sometimes in gear with the ac on) and it's fine through 1st gear every single time, it's when it shifts to second/third that the issue shows up.
So far, I've done an intake cleaning with seafoam and dumped a can in the gas tank as well. Did not make a bit of difference. The air filter is new and the oil is clean and full.
Any suggestions? I'll try to get a video of it tomorrow on my way to work in the morning.
specs are down below
RLC2020
RLC2020
Thanks for the responses so far. I did clean the throttle body and the MAF, forgot to mention that. They were both very clean, but I hit them anyway while I was in there doing the seafoam. I was assuming it wasn't a software issue as it only seems to do it when it's cold. Once it warms up it goes away. However, I will look into the tps as well. That part can be had for $50, worth just replacing it to see if that's the issue? I have no idea how to graph it, I have a basic OBII scanner. I'll purchase something aftermarket if it makes sense to. What do you guys recommend for that?
Thanks
Fless
Moderator
People's Republic of Colorado
Some of the phone/tablet apps can graph these, if you have an OBD dongle that transmits to the phone/tablet. I use TorquePro, $5 in Google Play with a OBDLinkMX+ Bluetooth dongle. I haven't looked to see if the app will graph that particular PID, but it does a good job of graphing others.
Other folks may have suggestions.
STORMIN08
try driving in tow/haul, the increase in shift pressure can replicate what a slightly better tune can do...see if that helps or changes.
i have my trans tuned to shift at 150 rpm higher 1-4, it is night and day better.
RLC2020
RLC2020
I'll try tow mode and see if that makes a difference. I disconnected the battery the other day to "reset" things. Seems to have made it worse. It was actually shifting bad in all gears for the first few miles I drove it after that. Now it's back to just doing the 2nd gear stumble, but it's worse. I almost got rear ended the other day, it stumbled and I had to floor it to get it to accelerate while merging. Really not sure if this is a trans issue or a tune up issue, but the engine seems to run fine everywhere else. I have 55k on it and no record that the trans fluid was ever changed. I'm contemplating doing a fluid / filter swap first to see if that makes any difference. I'm nervous to "tune" anything right now because if I have a real issue going on I don't want to cover it up or make it worse. I'm kinda lost right now as to what to do first. I'll try to get a good video of it asap
RLC2020
RLC2020
What hapened with doing the TPS and fuel pressure check?
I haven't done either of those yet. I need to acquire the equipment to do so. Been pretty busy lately and haven't had time to mess with it just yet.
I just reread the thread and saw that the OBDlinkMX was recommended so I ordered one off amazon, should be here tomorrow. Once that arrives I'll check the tps and post the results here.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Ok, I just asked because I don't want you to just throw money at it till some diagnostics are done and having that OBDlinkMX will be there for the future.
you could try just running around town in 3rd gear and watch the rpm gauge see if it bounces around when it stumbles in 2nd, you won't hurt anything doing this, it just rev's the rpm's up higher, that might give you a better idea of where the problem is.
Fless
Moderator
Not sure of the difference but I noted the MX"+" model.
RLC2020
RLC2020
I just double checked. I ordered the "+" model.
Once it arrives I'll be downloading the app and checking things out.
Also: This morning I drove the truck in Tow/Haul mode and it drove 100% perfect. Still not sure if it's the trans is upshifting too quickly and the engine falls out of the power band, or the engine is not running right which causes the issue. Either way, tow mode kept the rpms up and when it shifted into 2nd it kept pulling like normal. I'm thinking once I get the tps data and fuel pressure numbers, if everything looks good there then I'll just go ahead and get a tune for this thing.
RLC2020
RLC2020
So, to update this thread, i think the issue has been resolved. Believe it or not, I used some snake oil and I'm pretty sure the issue is gone. I dumped a bottle of the Royal Purple Max Clean fuel system cleaner in and I'm about halfway through the tank and it's running 100% smoothly at this point, even my rough idle has cleared up. I've been driving it pretty hard, lots of WOT pulls and drove in tow / haul mode to keep the rpms up for the first 3 days. I think this thing was driven by a grandma before me and the injectors were dirty. I'll update again if the issue returns, but it seems like it's good to go as of now.
OR VietVet
Willamette Valley
I recommend that if you have been running 87 fuel, that you run 89 or higher fuel for the better fuel system cleaning that they offer.
I run 89 for a tank full and then when down to 1/2 tank I fill with 91/93 and then at next 1/2 tank I go back to 89 and so on and so on...
02Lightning
That's a new one for me, "higher octane fuel contains better fuel system cleaning". As far as I knew, higher octane fuel just allows slower combustion so you can run more timing. Then if the vehicle is not tuned for it, the higher octane will leave more deposits in the combustion chamber.
OR VietVet
Willamette Valley
Yes, that is correct but the higher priced fuels also have more additives, at least at Chevron they do, that help keep fuel systems clean. You can always get fuel system cleansing additives and add it to the regular tank of gas that you may use.
Dh1280
