Noise-front suspension/chassis
TunasTwins
2005 Tahoe LS
Atlanta
I cant figure it out. Only makes the noise while driving. Sounds like something is loose, drivers side front. Its not a thud type noise. Its more like a click click click. Happens when hitting bumps/pot holes. You can hear it rattle a few times and then goes away. I've looked for bad bushings and checked the tierod ends which feels correct. Recently I noticed some noise when making a long left turn around 30-35MPH. I thought "is it the wheel bearing/hub?" But this thing makes noise when going straight also. I though about a brake pad that is chattering all of a sudden Could it be the ISS??
PLEASE ANY IDEAS WOULD BE GREAT. MY WIFE AND TWINS ARE RETURNING FROM EUROPE AND I HAVE TO CORRECT THIS BEFORE I CAN LET THEM RIDE IN THE TAHOE.
grayhoe00
GA
Front brakes from what im am told. i am having the same issue. thats the pad you are hearing shaking around.
TunasTwins
TunasTwins
2005 Tahoe LS
Atlanta
Wouldn't mind putting in some hawk pads. Thats pretty much what it sounds like.
TunasTwins
TunasTwins
2005 Tahoe LS
Atlanta
So it ended up being a piece of the star adjuster floating around in the rear brake assembly/parking brake drum!
gtbigup01
Columbus, GA
^ wow, glad you didn't start throwing parts/money at it like some folks do without knowing exactly what the problem is.
TunasTwins
TunasTwins
2005 Tahoe LS
Atlanta
I just bolted her back together. Hopefully I wont need the half of the gear for adjustment anytime soon.
moto
