No front heat
SmileB44Death
Seattle
I changed my thermostat recently and added some coolant to my system. However, my front heat and defrost are blowing cold air. My rear heat works perfectly fine but the front is not. I’ve noticed but inlet and outlet hose are cold connecting to the firewall. What do y’all think the problem is?
the problem is you can no longer feel heat with your hands, it would be impossible to have cold heater hose's and have heat at the same time, the heater hose's that go into the firewall also t-off to the rear. you most likely have a bad blend door actuator or 2 bad blend door actuators or broken blend door(s)
PG01
Up here to the right
3 things-
1st as doube said, actuator (s)
2nd not enough coolant
3rd flush heater core... been seeing thus alot lately.
David Smith
Savannah, GA
I had a similar issue. It was my heater core. I just flushed it both ways a few times and now I have heat again. My hoses were not cold. I would try and take 10 mins to flush the heater core. To me, it is probably the quickest and easiest thing to try.
Musicars
I have been fighting with similar issues. I have drained coolant a couple of times in the last couple months while replacing the waterpump, radiator, and flushing the reservoir. Each time it took about 4 days to get the front heat back. I added coolant a little each day until the reservoir stayed full. My assumption was air remained trapped. Could be from crud in core, probably will never know for sure, but at least the heat is back. I also tried overfilling a bit thinking that would save time. Big mistake as it just caused coolant to puke out the overfill tube. Only slow and steady worked for me.
SmileB44Death
SmileB44Death
Seattle
I’ve also notice it won’t let me change to the other air type. It lights up 4 times and just doesn’t switch. Does this mean it’s the blend door?
PG01
Thats recirculated air, sometines it has to be on an a/c function, cooler temp for that to work, try swapping temp first then air direction and see whats up
SmileB44Death
SmileB44Death
Seattle
Update: I changed my blend door actuator however there is still no heat. Should I flush it now?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Did you turn the knob and verify that the blend door is actually moving? You could also have a stuck heater valve or broken cable. You can check that by manually moving the valve and see if you get heat. Last thing I would check is often with vehicles with rear heating, air can get trapped in the system. You can try bleeding by removing the cap, jack up the front and let it run. Raising the front up will help the trapped air work it’s way out to the top
SmileB44Death
SmileB44Death
Seattle
Update: so when I would go about 70mph even though my fans were off they would still blow air . Even though the temp was on hot it blew out cold air. So a few days later I started my car up and I could hear knocking from the passenger side and bam my heat works now:D I wish it worked during the winter though lol
CrackerJack135
