2023 suburban rear heat not working
hollab
My rear heat has quit working on 2023 suburban. I took rear panel and checked the blend motor and it works, coolant is normal. Rear fan works fine and A/C blows cold. I have not been able to locate the fuse if their is one for rear heat, I found rear display but nothing else. Which fuse would this be/ labeled as. And if fuse is good what else do I need to look at?
Big Mama
Virginia
I’m not sure there is a fuse but I read there’s a control valve under the truck on the passenger side that can get clogged. A 2023 should still be under warranty. Have you considered taking it in?
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
H
hollab
Ok thanks, and I'm pretty sure warranty is out, but I dont like dealing with dealerships anyway just crooks
Big Mama
Virginia
Totally agree. You should have 3 years or 36000 miles of bumper to bumper coverage regardless of how many owners it’s had.
BadDaddy2003
