New to the forum, i have a 2004 Yukon with a 5.3 with a crank, no start issue
bonehead6026
2004 Gmc Yukon SLT, experiencing a crank, no start issue, getting gas, scanned for codes, none except for an EVAP code which i knew about. Any insight would be great. New to the forum so im hoping im posting everything ok. Thanks for any help.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in your generation truck will chime in. Lots of GMT800 truck owners here.
To assist folks is assisting you, please go into greater detail on exactly what you do and exactly how the truck responds, or doesn't respond, at the point of the issue's beginning.
Was any work performed on the truck recently?
What did you use to scan for codes? A quality bi-directional scanner, or a cheap scanner?
LsHart
Senior Member
So u can smell gas? Injectors need psi. What's the psi at fuel rail? As above, will it start on spray can?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum, from Oregon.
You need to answer the above questions. Been over 2 weeks since you posted.
jkhuntzinger
