New Heads
HoustonDidThat
Las Vegas
Since I have a #4 cylinder misfire and i've done the cheap stuff. going to dig into the wallet and get some new ones.
Any suggestion on what I should get?
ccapehartusarmyINF.(ret)
Gilbert AZ
okay yer having a misfire in cylinder and youve done some troubleshooting and now youve arrived at replacing the heads?
okay if you dont mind lets take a few steps back here before you start dishing out more money on a new set of heads to fix a misfiring cylinder
what have you checked or replaced so far im going to assume plugs and wires were the first thing also what year is your vehicle and what motor do you have
retorq
Kingman AZ
You should replace the heads with another set of stockers if you are going to replace them at all.
H
HoustonDidThat
Las Vegas
Sry for the delay..
I have a 1999 gmc yukon with a 5.7liter 350
"cheap Stuff" would be spark plugs and wires.
autolover3
Bismarck/Wahpeton, ND
Have you checked your distributor cap?
Also injector could be sticking. How many miles
---------- Post added at 08:34 PM ---------- Previous post was at 08:29 PM ----------
Also see your other thread that you have a ticking noise. You said you did new wires, makes sure they are all on all the way. Also could check valve lash
autolover3
Could just pull your cap off and check terminals and center post for wear in the mean time. Mine went out at 140,000 miles. Center post was worn so much the plastic was beginning to wear down.
HeavyHoe03
