New Headlights
yates ™
Resident Apple hater
Iowa
Light output is usually horrible with these types of lights. Find some that are not projector and you should be ok.
YukonXL04
The Riverboat
Arlington, TX
I have those lights on mine.
The halos and the 3 leds burn out pretty quick. Within 6 months. The light output with a halogen bulb wasn't half bad. actually better than the stock halogen light. When I put HIDs in them the sucked. so I swapped the projectors for Mini H1 HID projectors.
Kubs
Akron, OH
Why do they burn out? How did you have them wired up? LEDs are supposed to have a pretty long lifespan... Not blaming you, just curious what would make them so bad.
YukonXL04
The Riverboat
Arlington, TX
Just crap parts... I wired them as they should have been. They may have burned up a little quicker on mine because they were hooked up with the daytime running lights. Also pretty much the only time you can see the halos is at night with the headlights off. Not really dogging on them because they were extremely easy to retrofit a much better projector into. Which was my plan from the start
rossida
