need help
preshus
washington,IN
ok so the wheel bearing went out on the camaro . . . so since i don't have a
wheel bearing pulley i bought the whole wheel bearing and hub assembly . . .
well when i went to take the originall hub off i got the 3 bolts off but broke my
socket on the last one and striped it as that happend . . . so i spent 50 bucks in
tools that didn't help me at all trying to get this bolt out . . . figured i could
take the whole a arm off and just take it shop and throw the torch on it but
i can't even get the a arm off i got all three lock nuts off that i need to
take off i just can't get anything to budge and can't get a jack on it where i
need it . . . so dose anyone have any advise becaouse i have ben fighting
this car for 3 days . . . if so thank you . . .
purple 'hoe
Green Bay, Wisconsin
Do you have EZ-Outs? And if you have an air-impact that will help. Otherwise a big breaker bar or ratchet. EZ-Outs might be your best bet in getting that bolt out. Or try and hammer a socket on it and get it off. I'd try and not remove the A-Arms if possible.
Once you get that bolt out, I'd run to your local GM Dealership and see if they have those bolts in stock. Defiantly use the correct bolts on hub assembly's
preshus
preshus
washington,IN
well what happen was it was a 1/2 inch socket and i split the socket in to 3 pieces with
just my regular ratchet and my hands i don't know if the tool was just cheapley made
or if i had lil more muscle then i thought but when i broke it i rounded the bolt of
pretty bad so i went and got the gator grip which i broke it to so i went and the
extracter sockets and i can't get a grip with it . . . it just spins off . . . wd40 won't do
nothin cuz it can't pentrate inside it just goes out side . . . and the ez outs i don't have
a drill for them and when i worked in the shop i broke those things left and right
so i don't really wanna buy those and brake them . . . i'v even broke 2 pairs of
visegrips on the dam thing . . . i tryed channel locks but theres a *** right above the
bolt and it just defeats the perpose of those . . . so i have no idea what to do man im
out of money and options . . . i was only gonna take the a arm off so i could take the
whole thing into shop and put a torch on it but i can't even take that off cuz it won't
budge at all
purple 'hoe
budge at all
Then option two. You could hammer on a socket so that it won't slip off.
preshus
preshus
washington,IN
well ya i had to hammer the extractor socket on but it still sliped off so i guess i can try a
size smaller like you said but hell thats my only and last option i have
il give it a try in little bit
LI99HOE
Top Notch Tech.
N.Y.
Any way you could use a small grinder, or file to put some shape back on the head so that you might be able to get a socket on it? If so, when your done, tap on the head flatways with a hammer. Hopefully this will loosen up any rust/corrosion in the threads, and maybe make it easier to turn.
We would do this when we ran into this problem on industrial machinery, and more often than not it helped.
purple 'hoe
Never thought of this idea, but this is a pretty good idea. Seems like it would work if you could get some shape back on the bolt
Yote1
