need help
preshus
washington,IN
ok so the wheel bearing went out on the camaro . . . so since i don't have a
wheel bearing pulley i bought the whole wheel bearing and hub assembly . . .
well when i went to take the originall hub off i got the 3 bolts off but broke my
socket on the last one and striped it as that happend . . . so i spent 50 bucks in
tools that didn't help me at all trying to get this bolt out . . . figured i could
take the whole a arm off and just take it shop and throw the torch on it but
i can't even get the a arm off i got all three lock nuts off that i need to
take off i just can't get anything to budge and can't get a jack on it where i
need it . . . so dose anyone have any advise becaouse i have ben fighting
this car for 3 days . . . if so thank you . . .
purple 'hoe
Green Bay, Wisconsin
Do you have EZ-Outs? And if you have an air-impact that will help. Otherwise a big breaker bar or ratchet. EZ-Outs might be your best bet in getting that bolt out. Or try and hammer a socket on it and get it off. I'd try and not remove the A-Arms if possible.
Once you get that bolt out, I'd run to your local GM Dealership and see if they have those bolts in stock. Defiantly use the correct bolts on hub assembly's
preshus
preshus
washington,IN
well what happen was it was a 1/2 inch socket and i split the socket in to 3 pieces with
just my regular ratchet and my hands i don't know if the tool was just cheapley made
or if i had lil more muscle then i thought but when i broke it i rounded the bolt of
pretty bad so i went and got the gator grip which i broke it to so i went and the
extracter sockets and i can't get a grip with it . . . it just spins off . . . wd40 won't do
nothin cuz it can't pentrate inside it just goes out side . . . and the ez outs i don't have
a drill for them and when i worked in the shop i broke those things left and right
so i don't really wanna buy those and brake them . . . i'v even broke 2 pairs of
visegrips on the dam thing . . . i tryed channel locks but theres a *** right above the
bolt and it just defeats the perpose of those . . . so i have no idea what to do man im
out of money and options . . . i was only gonna take the a arm off so i could take the
whole thing into shop and put a torch on it but i can't even take that off cuz it won't
budge at all
purple 'hoe
budge at all
Then option two. You could hammer on a socket so that it won't slip off.
preshus
preshus
washington,IN
well ya i had to hammer the extractor socket on but it still sliped off so i guess i can try a
size smaller like you said but hell thats my only and last option i have
il give it a try in little bit
LI99HOE
Top Notch Tech.
N.Y.
Any way you could use a small grinder, or file to put some shape back on the head so that you might be able to get a socket on it? If so, when your done, tap on the head flatways with a hammer. Hopefully this will loosen up any rust/corrosion in the threads, and maybe make it easier to turn.
We would do this when we ran into this problem on industrial machinery, and more often than not it helped.
purple 'hoe
Never thought of this idea, but this is a pretty good idea. Seems like it would work if you could get some shape back on the bolt
ezdaar
Chat Troll
Redneck central, Aka Houston
Banging the Shiet out of the bolt head defiantly helps bust the corrosion loose.
Aswell as heating the bolt as hot as you can then using "Air in a can", the stuff used to blast crap from your keyboard.
Turn the bottle upside down so it blasts the liquid instead of air out. It gets VERY cold very quickly and can help Thermal shock a bolt loose.
preshus
preshus
washington,IN
Any luck?
not yet i gotta get a file first im very limited to my tool selection at the
moment
---------- Post added at 07:24 PM ---------- Previous post was at 07:22 PM ----------
ya that would be nice except i don't have a torch to throw on it cuz i can't get
the a arm off to bring the whole piece to the shop and do that . . .
---------- Post added at 07:27 PM ---------- Previous post was at 07:24 PM ----------
i think squareing it off like was mentioned earlyer should get it done just gotta get a
file first lol my gurl don't even have a nail file so ya like i said im pretty limited to my
equipment
preshus
preshus
washington,IN
ight so i have ben beatin the shit out of this bolt and still ain got no where . . . still
need to get a file but im starting to doubt that idea now . . . correct if wrong but i got
the top of the a arm off i just can't get the tie rod off and the bottom part of the a
arm off it just won't slide off the studs . . . im scared to keep beating on that part
becouse i don't wanna tear somthing up
preshus
preshus
washington,IN
threw some hydrogene poroxide on the studs maybe that will break it up some but can't
do that for the bolt i need out theres no penatration spot at all becouse of the type of
head thats on it
purple 'hoe
Well to take that Tie Rod off, take a hammer and hit the top of it down. It will just pop out of place. HOWEVER
Looks like you have a ton of room in there. Way more than what I was thinking. You sure you can't pound a socket onto that bolt and then remove it with a ratchet? Ask to borrow some tools if needed? If needed, try heating up that bolt. Heat usually breaks bolts away
Vise-Grips will work to. The biggest ones you can get. Make sure it's nice and tight on the bolt, and put all your effort into it.
preshus
preshus
washington,IN
well i beat the tie rod still no give i need a bearing splitter but iv ben smacken the
extractor sockets on that bolt and just when you think its gonna give it just spins off
so i don't know but i also beat the crap out of that bearing and i popd off something
like a splicer gear that was just behing the bearing but any ways i started hiting that
bearing reall hard thinking i could just smack it out of there but it didn't work . . . but
hears the complete messed up part . . . they tryed to tow the car since it was sitting
on jak so guy told me to hurry up and put it together and just move it for the day well
i did and wen i did nothing happend as if there was no problem with the dam thing in
the first place . . . i'v ben driving it and there isn't no thumping or rocking so ima take
it to the shop sometime and throw the torch on it and go head replace the part im just
mad i spent all that time and then theres nothing wrong mabe the bearing was just out
of place and i put back in when i started beating on it
purple 'hoe
Did you shake the front tire down and feel any movement? If you grab the tire at the top and bottom and shake it, you'll feel some play. Have someone watch and see if you see any movement on the upper ball joint, lower ball joint or wheel bearing.
preshus
preshus
washington,IN
ya theres no play at all except when the wheel is of the disk has play but
i was told thats the way its suppose to be . . . still don't have any problems
so far so im just holden my breath for now . . . i got the computer hooked up
to it becouse abs inop came on i had them clear all the codes becouse it
was my fault that light came on i took the little gear off that the sensor runs
off of lol so other then that its fine . . . its got some tranny slip but i don't
think that could of caused the shakeing . . . i guess i just need take it to
dealer when i can afford it lol
worleytrev93
