Need help wiring escalade Bvlgari clock.
denalianyone
NYBlackLade08
New York
I just received my escalade bvlgari clock and connector. The connector has three wires and did not come with any instructions. I cant find any tutorials online to installing this. Did anyone do this mod b4? Any help will be greatly appreciated.
Grebbler
Parts is parts...
Michigan
I have never seen the clock. If it's just a normal clock I would assume the leads are Ground, B+ for clock and the last lead for the light to tie into the dash dimmer circuit.
denalianyone
denalianyone
NYBlackLade08
New York
The clock is standard in the 02-06 escalade models, incorporated into the power/storage section of the center console. Thanks for your quick advice.
ndavis0001
Davis Motorsports
Jacksonville, FL
well you could do a soft test... run your 3 wire leads and test this to that and this to that until you pinpoint which are which...
in the meantime ill try to find you a diagram... im bored
Anthony
2004 Tahoe LT (MA)
Westen MA
*Any updates to this?*
I just got an Escalade console (Clock area+ Cup holders +Clock) off eBay and looking to have the correct wiring to make ti work in my 2004 tahoe. Any input please?
denalianyone
denalianyone
NYBlackLade08
New York
I used the wiring diagram from alldata. Ill try and post the pic later tonight.
Nyc2011Denali
