YukonXL813
- Joined
- Jul 14, 2024
- Posts
- 6
- Reaction score
- 3
I’m hoping someone with GMT800 experience can help because I’m running out of ideas.
This all started after replacing a brake line at the ABS module. Since then, the brake pedal goes straight to the floor with almost no resistance and I have little to no braking.
Here’s everything I’ve done so far:
Codes I’ve had during this process:
I repaired the issues related to those codes. The ABS light is now off, but the red BRAKE light is still on.
Current symptoms:
At this point I’m trying to figure out:
Any advice would be greatly appreciated. I’m trying to diagnose it correctly instead of throwing more parts at it.
- Replaced the damaged brake line.
- Installed a new master cylinder.
- Bench-bled the master cylinder before installing it.
- Bled the master cylinder again on the truck.
- Replaced the EBCM (electronic brake control module).
- Swapped the ABS pump motor from a donor truck.
- The original hydraulic ABS block is still on the vehicle.
- Performed an automated ABS bleed with a Snap-on Solus Edge.
- Manually bled all four brakes multiple times.
- Verified brake fluid is reaching the ABS module.
- Cracked brake lines at different locations to verify fluid flow.
- Checked for external leaks and haven’t found any.
- C0265 (EBCM Relay Circuit)
- C0235 (Left Rear Wheel Speed Sensor Circuit)
Current symptoms:
- Brake pedal goes completely to the floor.
- Little to no braking.
- Bleeder screws only produce dribbles instead of a strong stream of fluid.
- No external leaks.
- Could the original ABS hydraulic block have failed internally?
- Is there still trapped air even after an automated ABS bleed?
- Is there another bleeding procedure specific to these GMT800 trucks?
- Has anyone had this exact issue and found the root cause?
