My BIG Audio Project!
jdpber
GOLD MEMBER
The America
Looking good I have 200sq/ft dynamat ordered to do mine soon. Stoked to see final project
GalaxyBlackEsky
BlackedoutLT3
MD
Damn that is one hell of a project. I did the same thing with my old show eclipse ripped the whole interior and had the whole thing done in fiberglass. Told my self I wouldn't touch this interior or take anything out.
A
AMG ETR
Got a few hours to work on it today...
Finished the Hushmat on the roof and added Hushmat Megabond Foam (1/4") as well.
Applied Hushmat to the backside of the door skin
Ran JL Speaker Wire To The Rear Doors 2 16GA For Midrange and Tweeter and 1 12GA For Midbass
Nice and clean through the Molex Plug
Regards,
Evan
THE YETI
Director of Operations
South FL
Coming out pretty clean!
Regards,
Robbie
A
AMG ETR
Wrapped all my trim in Black Gloss Vinyl. Looks great and I can remove it anytime! Also got my headliner installed along with some LED bulbs in the dome lights.
Should start seeing some actual audio progress next week! My 2nd of 3 shipments from JL Audio arrived yesterday so I have just about everything (Yes that large pile in one of my first posts was not even all of it)!
Evan
GalaxyBlackEsky
BlackedoutLT3
MD
Looks good. I thought about doing the vinyl for my interior trim but I just traded my stock with B.G. painted black trim. Love the headliner. If I had time I would do this to mine.
Tahoewhat
Ballin' on a Budget
TX
headliner looks good.
What kind of led's did you get?
Hows it coming along?
THE YETI
South FL
what'd you use to make your ac vents black?
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
You should suede the pillars while your at it!!! I hate how gm makes the pillars plastic!!! Just a thought looks sick deffinatly following this!!
A
AMG ETR
Between being out at SEMA and just plain busy there hasn't been much progress till yesterday! Started the enclosures and nailed down a good plan for how everything is going to lay out (though my installer Tom loves to surprise me...)
Here are a few pics:
After sitting in the trunk for 2 hours one of my installers Tom started cutting wood:
Enclosures Started:
Cutting More:
Basic Enclosures done:
On of my other installers surprised me and custom mounted the control for my Audio Control DQXS (Digital EQ) in my dash for me!
And finally, I ran all of the 1/0 Gauge from the 2nd battery in the front to the rear (where I will have a third battery):
Hopefully get some more done this week...
Evan
I don't remember what LED's they are, bought them from a local store that carries that type of stuff... They were 6 LED's in each wedge bulb....
This is the stuff:
I will for sure be wrapping the pillars in suede :) I agree the plastic looks CHEAP!
Regards,
Evan
A
AMG ETR
Spend a couple more hours on it yesterday... I made all the 8" and 6.5" speaker rings while my installer Tom continued on the enclosures... Also finished up the 1/0 run up front with a JL ANL Fuse Block.
Starting to look like something!
Evan
S.L.A.B
houston TX
what all are you useing to power the subs? im thinking about khc1800 battery for when i get my 2 12 alpines type r's and a component setup.
A
AMG ETR
Power as in electrical system? I have a DC Power Alternator on the way (270amp) that will power an optima yellow top and Shuriken BT120. This will be completely separate from the stock alternator powering the other yellow top battery which will power the truck. I do have 1/0 gauge connecting the 2 yellow tops up front tho with a circuit breaker incase either dies I can flip the switch and send power over! As for amps, 6 JL Audio amps... 2 HD600/4s, 2 HD750/1s, 2 HD1200/1s.
Evan
cdhpc2
