John03Z71
- Joined
- Mar 27, 2014
- Posts
- 43
- Reaction score
- 14
About 10 days ago I replaced the knock sensors on my '03 Tahoe Z71, and replaced the intake manifold gasket while I had it off with a genuine Fel-Pro gasket. After I put everything back together and took it for a quick test drive down the street and back, I could immediately feel an increase in throttle response and overall performance. However, beginning the next day when I started "really" driving it I began noticing misfires, hesitation, sputtering, etc. when I accelerate, especially from a stop or when under load (AC on & going uphill for example). If I gently accelerate from a stop and get up to speed it's not too noticable, but if I really step on it from a stop it hesitates and sputters so much it takes almost 5 seconds to get a little speed/momentum up to where it'll not be so bad. Really dangerous when turning onto busy roads.
Also when pulling into a parking spot or just coming to a stop in general, if the AC compressor is on when I finally come to a stop the idle dips so low it sounds like its going to stall, but then goes back to normal after a couple seconds.
Does anyone have any suggestions what this might be caused by? New plugs & wires about 10k miles ago. No check engine light.
Edit- also have noticed some black smoke right after starting up when the engine is hot (not from cold start). Not sure if it's related.
Thanks in advance!
Thanks in advance!
