Mirror Courtesy Lights
ford141
So, I've have my 2008 Yukon Denali for 4 years. I recently discovered that it has courtesy lights in the side mirrors, but I have never seen them working. I thought maybe they needed new bulbs, but I replaced them and they still don't work. When are these lights supposed to come on? I figured they would come on when I unlock the doors at night but they don't.
View attachment 228716 View attachment 228717
if you have a aftermarket alarm/fob they will not light up, if you have the factory fob then it may be a setting in the Drivers information center to turn the lights on/off, I added a viper alarm so I had to wire mine in to come on when I unlock the truck.
DougAMiller
Colorado
I haven't tested this to be certain, but I believe they are part of the perimeter lighting option in the DIC options menu. Try checking to see if perimeter lighting is enabled.
ford141
ford141
That was my first thought too, so I went through the DIC menu but I didn't see an option for that. I'll dig through it again to check.
I do have the factory key fobs, so that's not an issue.
Bigkevschopshop
Northside H-Town
I had found mine after 1.5 yrs owning it... Pulled the lights out, replaced bulbs, still no work... DIC has approach lighting set and there was another one in the menu... I clicked it on, and the lights will light up for about the first 15 second or 30 after hitting unlock... Check the DIC and play with a few settings but don't go changing languages...
PG01
Up here to the right
Que’¿
St. Louis
Yup, approach lighting and exit lighting
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
ford141
ford141
2001 Yukon SLT
Both approach lighting and exit lighting are turned on. They have been turned on the whole time I've had the car.
CKendrick
