Mike's 2013 Tahoe Build
mjenk430
mjenk430
Unionville, VA
Will do, I'll try that tomorrow or Monday. I knew I should have bought more than two machine screws while I was at Home Depot.
---------- Post added at 11:04 PM ---------- Previous post was at 11:01 PM ----------
Truck looks great.
I used a heat gun to reshape my plastic fender liners.
You have to watch for a change in the shininess of the plastic....when it does push on it. I used a piece of wood contoured round.
From my Walkie Talkie
Thanks man.
I'll give the heat gun a try. It rubs at the inside of the liner, not the lip or the top. There is actually a little bulge in the liner that is rubbing. If I can just get that pushed in, I should be good to go. I'm going to wait until the 305/35/24's arrive so I can see how much work I am really going to have to do.
Goodinblack
I Like Tacos
Dirty South
Cool...
I did mine a while back....
Hey.... be careful if the AC lines running behind the liners too.
NORCAL SS
SUV SUSPENSION GURU
btw flip the upper bolts the opposite way on the rear shocks. since your putting on 24s many times ive had trucks come in where the bolts hit the tires especailly when you lower it and pass side gets pushed out more and drivers side taps it.
mjenk430
mjenk430
Unionville, VA
Thanks for the heads up, I'll add that to my "to do list".
NORCAL SS
SUV SUSPENSION GURU
no prob Ive always flipped em but I also get trucks that are lowered somewhere else and whoever did it doesn't know the little tricks on these trucks that make a big difference
mjenk430
mjenk430
Unionville, VA
Wheels come tomorrow, I'm excited. I'll snap pics and post them as soon as I get them on.
mjenk430
mjenk430
Unionville, VA
Removed roof rack last weekend. Forgot to post it up on the build thread...
mjenk430
mjenk430
Unionville, VA
No, still need to order it, still need to fix the one bolt I f'ed up too. Did get the wheels on this evening and the door molding stripped off one side. :) :) :)
What do you guys think?
---------- Post added at 08:50 PM ---------- Previous post was at 08:46 PM ----------
I never zip tied my e-brake cable on the drivers side, and I noticed when I had the wheels off it has started to rub a hole in the rubber of the air shock!! Actually a few fibers showing in the rubber, definitely need to take care of that tomorrow.
I have some serious rubbing going on with the new tires in the rear. Going to take the heat gun to the fender liner tomorrow also.
NathanJax
Vacation Nathan
Jax, Fl
Lookin good
NathanJax
Vacation Nathan
Jax, Fl
White all of them
Bob LaFord
