chaingun427
OBS Mad Scientist
Planning on doing an NV4500 swap into my white 98 Tahoe. It's currently a 4l60e/np246 autotrac setup so I'm trying to compile all of the information I'll need to do the swap in one place. The donor is a 2000 k2500 4wd with an NV4500 and an np241. it's been rolled but still starts and shifts fine.
For the most part it seems fairly straight forward, at least at first. The old motor tranny and transfer are already out and gone which leaves me with just the motor.
The easy part is the mechanical assembly,
1. pull dash, steering column, and carpet out of the front.
2. install clutch pedal, and brake pedal after knocking out hole in firewall
3. cutout floor pan for shifter and 4wd shift lever (based on measurements from the donor if it's not already stamped) not cutting carpet at this time
4. install pilot bearing, new pressure plate and clutch
5. mount transmission only, drill new locations for the cross member
6. install transfer case and attach 4wd shift linkage
7. driveshafts( not sure if I can use the front from the donor) Will need to find correct shafts if existing won't work.
8. connect and bleed slave cylinder
9. disconnect and remove tccm
Electrical is going to be the big issue with this swap as i've got a few big questions i haven't answered yet.
1. wire vss from np241 into rearmost speed sensor from the 246 (green and purple)
2. splice pink and green wires on the shift selector to enable reverse lights
3. wiring harness near the shift linkage connects to front axle to engage it, as well as the 4x4 indicator light? (according to Btempy on fullsizechevy. Ground one end wire,Cut the Grey/Black-possibly light blue? wire on the actuator and splice it into the 3rd wire coming from the pigtail. middle wire goes to the 4wd light?)
The biggest issues I think I'm looking at are going to be
How do i wire up the front axle actuator to the shift linkage?
Does the 4wd indicator have constant hot, and the transfer case just completes the circuit?
Should I swap in the manual computer from the donor, and if so how do i rewire the fuel pump to send the fuel level to the computer first? IIRC that started in 99
As always advice and insight are appreciated, I'd like to get this build on the road by the middle of summer if at all possible.
One further complication will be the 383 stroker i'm building, i'm not sure if the clutch assembly from the 350 will work on it or not...
