Lowering the 2015!!
NORCAL SS
SUV SUSPENSION GURU
Update. Getting a new z06 so not getting new escalde butttt
The 2509 or 2511 belltechs do not fit like I thought.
You can still do my strut mod on the new trucks in front for up to 2.5 drop.
upper a arm on my rental had same bushings as 07 up so belltech camber kit 4957 will work.
Rear kit my springs fit in and the extenders and trailing arm relocators from 07 up work.
Only thing I didnt have to test on the truck was the swaybar endlink relocators.
Im planning to rent another one in 2 weeks then ill get the endlinks in and full rear kit and put up pics. Ive been talking to Roel at belltech so spindles for 2015 are.few months out at this point. Djm will be releasing the 3 inch upper and lower a arms also.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
If the 2015 ups use the same upper crossmembers as the 2006 up trailblazer ss's as many of the 2007 up do now then I think i might bag the rear using the tbss airbags.
Brooklyn hoe
I know this does not have anything to do with the 2015 tahoe but NORCAL SS if thats your truck on ebay for sale it is hot much props on it.
yates ™
Resident Apple hater
Iowa
I can sell you some bags if you don't want to use those :pepper: :whip:
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Right on thank you.
---------- Post added at 07:25 AM ---------- Previous post was at 07:24 AM ----------
I gotta ask what are you doing about the magnetic suspension?
Easy longer mag links like I do for the ctsvs I lower.
---------- Post added at 07:26 AM ---------- Previous post was at 07:25 AM ----------
All good. Ill be towing also so the tbss bags do 6000 pounds plus I will still have the autoride to help more but if I dont go with that set up ill let you know.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Well ordered the belltech 2511 spindles... and trucks not here for 3 more months lol
Steve1081
Interested in 1.5" drop in the rear to level my 2015 Yukon XL with tow package (auto level rear suspension). So I'm thinking that is similar to autoride on last gen.
Any idea if the parts from the last gen would work?
If not let me know if you are interested in a test mule for the rear only on a '15.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Yes it works.
Springs and shocks are 265 shipped and I will send you autoride links.
---------- Post added at 09:13 PM ---------- Previous post was at 08:17 PM ----------
Yes it works.
OH Yah sorry 2509 spindles work fine in front also. 3 or more do the 2511 spindles for front.
Steve1081
Yes it works.
Wouldn't you not want to replace the shocks on an autoride? Isn't that what is air controlled? Or am I confused?
Also, what # spring out back?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
meant shock extenders and rear are belltech custom 5305 plus 1 inch springs. if you do the 2 inch springs will only lower 1 so have a baych here which i also posted in my vendor section that will work
JeffK
