Low oil pressure but no noise
Leonard country
I have a 04 yukon with 5.3 was told last owner tried everything to get rid of low oil pressure nothing helped. The low pressure warning is on but truck has no valve rattle ticking or knocking this is the newest thing I've ever owned and only thing with 5.3 always been a 350 guy any ideas
Did you confirm oil pressure with a mechanical gauge?
Did he replace the camshaft bearings? Does the oil pressure fluctuate at all?
Fless
Moderator
People's Republic of Colorado
Post up some details of the rig: mileage, etc., and a list of what "tried everything" means. What repairs or tests have been done?
Had a recent oil report by, say, Blackstone Labs or somewhere else?
Dbeal82
I had a similar situation with my 6.0L. I changed oil pressure sensor and screen. Truck runs fine now. If that doesn't work, I have heard that it could be a bad o-ring on oil pick up tube.
Fless
Moderator
Which is why I requested more detail. Without knowing what's been done, we can toss all sorts of suggestions out there. Need more info if help is wanted.
rockola1971
Indiana (formerly IL)
I suspect that the oil pressure gauge is wrong. If there is one thing a GM engine wont tolerate, its low oil pressure. Youll spin a rod or main bearing or throw a rod right out of the side of the block with low oil pressure. The valvetrain would sound like a sewing machine before it got that bad. Its not uncommon for the before mentioned screen to get plugged up at the oil pressure sending unit. Quick and easy check. Another common problem is incorrectly installed or just old and split oring on the oil pickup tube. Or of course a worn out oil pump.
Welcome to the Forum from NH.
Pics of the truck, please.
JonnyTahoe
Minneapolis
You have Oil Pressure if you didn't you would know it like Rockola mentioned. If you have ever done a oil change but did not fill your oil filter before you installed it you may have heard a lifter tick for just a few seconds then it goes away when the filter is full of oil and the engine has pressure.
E-Diddy
Here's my experiences:
I've had a 2002 gmc yukon with 5.3L, made lifter noises when first starting, especially when cold outside, since i got it with 90,000 miles. Oil pressure is over 40 psi at idle, mobil 1 oil changes. Engine runs great.
The 2007 suburban with 5.3L with cylinder deactivation ate 3 qts between oil changes, got an oil warning light, oil was low so topped it off. OIl light still on. Checked oil pressure with mechanical guage, its a pain the first time since at the back of the intake near firewall and is done by feel, pressure was fine, replaced oil pressure sending unit with AC delco and screen below it (use a bent pic to remove, they are cheap so buy two just in case you lose it)...fixed problem...probably got clogged when i ran it low on oil.
S1W99
I had an '07 with the same problem. I put in a quart of transmission fluid into the oil. Ran it for about 20 mi did a full oil change and never had the problem again. My sweater. Bye Happy for Bye Happy for you
rockola1971
It is not a good idea to run an engine under load (AKA on the road) with a quart of transmission fluid in the oil. Transmission fluid does not have lubrication properties of oil which is why we put oil in the crankcase and not tranny fluid. Sure in the driveway at idle to free up sticky lifters then drain and complete oil change which ive done on many vehicles but I would never drive a vehicle out on the road with tranny fluid in the crankcase.
L
Leonard country
They replaced the sending unit but not the screen truck has about 200k on it I ordered screen at pressure sending unit and oil pump and pick tube waiting on them to arrive I tested oil pressure on side of block has about 38 pounds warm I didn't have the correct adapter to test at the top and I wasn't sure what ecm would do if I unhooked gauge sending unit also tried a new cluster seeing as the tac was not working
Durobans
