Low oil pressure but no noise
Leonard country
I have a 04 yukon with 5.3 was told last owner tried everything to get rid of low oil pressure nothing helped. The low pressure warning is on but truck has no valve rattle ticking or knocking this is the newest thing I've ever owned and only thing with 5.3 always been a 350 guy any ideas
Did you confirm oil pressure with a mechanical gauge?
Did he replace the camshaft bearings? Does the oil pressure fluctuate at all?
Super Moderator
Elev 5,280
Post up some details of the rig: mileage, etc., and a list of what "tried everything" means. What repairs or tests have been done?
Had a recent oil report by, say, Blackstone Labs or somewhere else?
Dbeal82
I had a similar situation with my 6.0L. I changed oil pressure sensor and screen. Truck runs fine now. If that doesn't work, I have heard that it could be a bad o-ring on oil pick up tube.
Super Moderator
Elev 5,280
Which is why I requested more detail. Without knowing what's been done, we can toss all sorts of suggestions out there. Need more info if help is wanted.
rockola1971
Indiana (formerly IL)
I suspect that the oil pressure gauge is wrong. If there is one thing a GM engine wont tolerate, its low oil pressure. Youll spin a rod or main bearing or throw a rod right out of the side of the block with low oil pressure. The valvetrain would sound like a sewing machine before it got that bad. Its not uncommon for the before mentioned screen to get plugged up at the oil pressure sending unit. Quick and easy check. Another common problem is incorrectly installed or just old and split oring on the oil pickup tube. Or of course a worn out oil pump.
Welcome to the Forum from NH.
Pics of the truck, please.
