Lost Cruise Control Set Button
Jhwhite05
Hey everyone.
2009 Yukon Xl, 5.3 4WD.
Today I pushed my cruise control “set button” only to discover it stopped working.
I’d really appreciate your advice for fixing it! We do a lot of long road trips, and cruise control is a game changer for us.
What do you think is going on?
tooleyondeck
Northwest FL
No.
Interesting connection, though. What was your thought?
It is a known issue that LED tail lights will disable your cruise on certain models, I'm not sure if the 900s were affected by this. The system checks for resistance at the tail lights and with LEDs having much lower pull, the system thinks your brake lights are out and therefore won't engage cruise. The fix is typically resistors at both brake lights.
In your case I would start with the fuse, then check your steering wheel switch and brake light switch. Here is a video regarding the brake light switch issue:
Jhwhite05
Jhwhite05
That’s really helpful. Thank you. I’ll check that!
Geotrash
Dave
Richmond, VA
Hey everyone.
Super common to have the brake pedal switch fail on these also. Try pressing the pedal lightly while driving with no one behind you, and letting it slam back to the top of its travel as your foot slips off. Then try engaging the cruise. If it works, it's your brake pedal switch for sure.
Jhwhite05
Jhwhite05
Ok! I will try that and report back!
Just Fishing
Can't fix stupid
Utah
Mr Bean Waiting GIF by Bombay Softwares (GIF Image)
Jhwhite05
Jhwhite05
Hope you feel better soon! There's definitely some crud going around. My son has been home sick with a 102º fever for the last 2 days.
Yeah, totally. My wife got a flu-thing and it lasted 2 weeks! Crazy. I’ve got a lighter version, so I’m planning on bouncing back asap!
Mosska
Start by checking the fuse related to the cruise control in your vehicle's fuse box. A blown fuse could be a simple and quick fix.
Cruise control systems often disable when the brake lights are malfunctioning or the brake pedal switch is faulty. Check if your brake lights are working when you press the brake pedal. If not, it might be related to the brake switch.
John Ley
This seems crazy but the last 10 PPV I bought the cruise would not work on the way home. Went to my buddies shop the next day and he asked if I had checked the fluid level in the Master cylinder and I said no what does that matter. We raised the hood and it was low, filled it to proper level and cruise has worked flawlessly ever since. He told me the connection but can't recall it now.
mikeseay
Air Force Supporting Member
Kingston Tn
Mine would work fine in the daytime but not at night when my taillights were on. You might check to see if it works in the daytime.
ZaZaZazzels
