Freedom Motorsports
- Joined
- Jul 16, 2011
- Posts
- 933
- Reaction score
- 20
Since you are replacing the gear box go ahead and find yourself one of these to remove the pitman arm. For the idler arm you can use the same thing or go to autozone and ask to use their pitman arm puller from their loan a tool and use it on the idler arm. The one most autozones keep on hand will not fit onto the bottom of the pitman arm, the right puller can be had if ordered at carquest, it is a similar design to the one at autozone, but smaller with a center bolt with a lower profile.
Loosen bolts on the idler arm, and remove. Do the same with the pitman arm. Remove the inner fender liner removing the push tabs using two screw drivers in the opposite tabs to pull them out. Careful there, don't stab yourself.
Once out, use a 15 mm socket or wrench, (rachet wrench does great) to remove the bolt connecting the intermitent steering shaft to the gear box input shaft. When the bolt is out wiggle and work the top shaft upward to remove it from the gear box shaft.
Disconnect PS fluid hard lines at the top of the gear box.
Once that is done use I believe an 18mm socket to remove the bolts on the outside of the frame rail in the fender area that are holding the gear box on.
Reinstall new parts in opposite order making sure to torque everything as you go and you should be good to go.
