I have the XJ shaft in my '92 ECSB, did WONDERS for my steering. Its as tight as my Tahoe now (also got new tie rod ends, pitman arm, and idler arm when I did my lift kit). Its a super easy mod. Got my XJ shaft off eBay for like $30. 84-96 XJ shafts work, NOT Grand Cherokees, just normal Cherokees.
Chris,
Was this just a drop in swap, or did you have to make/modify anyhting to connect the upper and lower shaft?
I found one on ebay, and want to know before I pull the trigger and take it apart again.
Eric
I did, and it didn't. I gave up on it a long time ago. Did you have your steering sensor under the steering wheel replaced? That's apparently been the problem on 97+ models.
