Looking to buy my frist 01-05 Tahoe. What problems should I look for?
Tahoe Noob
Hi guys,
Im looking to buy a 01-05 Tahoe I am located in SoCal. Budget is $3000 Looking for some something in the low to mid 100k mile wise. Hoping to get another 100k+ of it.
Just wondering if you guys could share some problem areas to look for mechanically. This will be my first time buying from a private owner. I am noticing that some of the ones in my budget have expired tags or close to expiring. It makes me think they won't pass smog. I am able to borrow one of those scanners that you plugin and will give you problem codes. May you can share some major codes to watch out for? Also, the ones with leather interior have big tears on front seats. How do you guys recommend dealing with that other than a seat cover? Is it pricy to get reupholstered? Like my name says I am a Tahoe newbie I look to you guys for some words of wisdom. I am not a mechanic in any way but I own a fair about of tools and can do basic oil changes and such. I am not scared of getting my hands dirty and looking up DIYs here and on youtube.
Thanks for your time!
Welcome. Off the top of my head--biggest thing is maintenance. Very helpful if you can get some kind of records. Oil change intervals, trans fluid changes, things like that. Also, transmissions. A known weak point on these rigs. Check fluid level, color, and smell. Make sure it shifts correctly and smoothly. No clunking or very long shifts, could mean a big $$ bill. Check the rest of your fluids and levels. Make sure water pump isn't leaking and there's no staining on or around it. Check for any engine codes--they can easily be cleared. They sell leather replacement covers on ebay and other sites pretty reasonably priced. You also get what you pay for--so keep that in mind. There's a few other common issues which escape me at the moment. Good luck and let us know any other questions.
Check all the basics as you would for any used car. Aim for an '05-'06. Don't get a 4WD or AWD if you don't need it. If it was maintained, it shouldn't need anything more than what you'd be capable of with some forum and YouTube guidance.
HiHoeSilver
Away!
Chicago
Hi guys,
Did you read through this?
https://www.tahoeyukonforum.com/thr...g-a-00-06-nbs-tahoe-suburban-look-here.61834/
Tony and Dub make good points. Agree on 05-06 if possible, as they have the electric fans. Second choice would be 03+. 03 is when they really figured this generation out, imo, and it only got better through 06.
If the check engine light is off, chances are you won't see any stored codes. Look for pending ones. This probably means the seller cleared them to get the light off, and it's about to come back on.
A well maintained specimen is definitely the biggest thing. Look for the telltale clues of how the previous owner cared for it, buy don't let a $200 detail job fool you.
Avoid one that has done a lot of heavy towing if you can, imo.
Look for rust on the inside bottom edges of the doors. Look close. It comes from the inside out usually.
Also, don't forget about Yukons or Escalades, either.
adriver
Theres a sticky with this exact title. HiHoeSilver posted it for you, right in the thread.
$3K is going to be too light for something with low 100K mileage. However, Something with 200K (that's in your price range), will still go another 100K if taken cared of, and you continue to do so.
05-06 has efans, but with your budget I would keep it open to 2000-2006.
You can get cloth also (which some from hotter climates prefer), or you can always buy replacement covers, replacement seats,
From my searching here's some stuff I noticed:
Learn what the VIN digits mean (and you can some times tell more than the others just from that).
https://www.tahoeyukonforum.com/thr...tailed-vin-info-for-free.109476/#post-1306586
ENGINE: You're not getting a 6.0L for that budget, unless you can find someone looking to sell a denali quick, and you have cash to check it out right away, or maybe at an auction. You might want to look around and see if ther are any in your area that you can make it too. These vehicles can be on there quite frequently. Its a gamble, but if its low enough and you can do the work yourself to fix something nothing is too expensive that you should be down for long. See if you have any local police autions, or I like hibid.com There are some automotive only auctions too. Iaai.com is one that's easy to use. You will most likely need to be flexible with an auction on probably color, but there are can be some really good deals if you get lucky.
The 8th digit of the VIN is the engine code. The 4.8 has less power and a torque curve that doesn't kick in till way too late. At least get the 5.3, most sellers don't even know what they have. I saw more of them advertising it had a V8 (which they all do), then mention which one.
V 4.8
T 5.3
Z 5.3 FF
Not sure if you wanted 2WD, 4WD, or AWD, but being in SOCAL, probably 2WD.
Theres a lot we can go over, but we won't out of the blue. Search, and see what you come up with then ask specific questions or go into as much detail as you can, and we will try and help guide you. What will you be using it for? What mods if you any do you plan on doing to it? What is your driving history, (cars years, use, etc).
I'm going to make a guess, because it sounds like you are younger than most in here, so I'll say this: Don't take shit from anyone just because you like there vehicle. Hold firm on your ground. You don't want to blow your budget only to get caught with a major repair. If you show up with cash, like the vehicle and the smog is nearly out, tell them you'll buy it once it passes smog. It doesn't take long, and you can go and get it done right then. If its got time, and even if it doesn't, you should be able to look up the history of the vehicle. If it wasn't meant to be, don't worry, there are plenty of them out there.
Keep in mind also, that anyone who has sold a car before will tell you its a HASSLE! People call, don't know shit and want to just talk. Some people want to ask you stupid questions that don't matter, or that you have specifically written down in an ad. People say they will buy it right then, and never show up just to ghost you on the phone hours later to see if they are still coming over. There are USED car dealerships EVERYWHERE simply because people don't want to deal with selling there cars in private party and are willing to take less than what its worth not to deal with it. Then those dealerships make enough to have a profitable business by doing nothing more than washing a car, and charging for dealing with all the BS. So when you call someone and they sound short, or frustrated, its because you're probably the 10th person who called. There were probably two that didn't show up after they said they would. Six of those first nine people all asked the same thing "Is it still for sale?" After everyone of them the seller wants to say "well is the ad still up *******?" then they ask, "What's the lowest you will take?" without ever asking a single question about it or wanting to come check it out. (that is such a childish, annoying ass thing to hear). If you don't have the full amount, be honest and I'll tell you not to waste your time, or I'll think about it. Half of those who wanted to know how low you will go, are just trying to get a seller to go even lower than that and think they are negotiating from that point. If someone is asking $4K, just tell them you have $3K and if you come check it out would they even consider it? Don't waste your time or theirs if not.
So.. Start now making your list of what you want to know, (specifically what options, condition, records, problems, smog, etc... ) WRITE THIS ALL DOWN so you don't forget and its ready. Then see what they have already answered. What I personally like and like to do is call first (or text if they say they prefer it), and first thing you say, is you are interested in the vehicle, and have some questions you would like to ask, do they have a few minutes to go over it, and then hopefully arrange a time to meet and check it out if everything sounds good. I'm not telling you to do what ever they want, but if you can make it easy on them, and be straightforward, professional, and honest with them about it, (NOT dick around) you will put them in a better mood, and have your best chance at them willing to come down on the price a little.
Never check out a vehicle at night. Doesn't matter if you are in the lighting aisle at home depot, there will still be scratches and dings you won't see during the day. Personally, every vehicle I have bought we test drove it in a public area, then we met at a 24 hour licensing office if you have those near by. It costs IIRC $11 to skip the DMV line, and we had everything changed over right then and there, and that was where we exchanged cash. I made sure they knew what the plan was, (showed them a balance receipt from the ATM that day), and after the test drive got the cash, and then met them at the title place around the corner. All in, it took a couple hours, possibly over cautious, but you never know who you are dealing with if its a private party.
Carfax is only a few bucks, and some times you can find someone who can run one for you. It may not show every accident, but it will show you if its had steady mileage, if its been up north, if there are any dealer service records with a gap, if there are any liens on it (which shows someone didn't have cash for a while to keep up with maintenance).
There's a lot more, but its your turn....
wjburken
Eastern Iowa
Agree.
When I’ve tried selling cars privately, these two questions were the most annoying.
Make sure you know what similar vehicles are selling for in your area. Just looking at KBB is not enough. Do your research as the person who is selling has most likely done theirs and know what a fair price is. I actually had a guaranteed amount a local dealer would pay me for my vehicle so I knew my bottom dollar. I had one guy that I knew tell me I was asking way too much for my truck, but when he saw it on the local dealers lot for $5000 more than I was asking, his wife chewed him out for not knowing what he was doing.
adventurenali92
Big Bear Lake, ca
Lots of really helpful knowledge and info in these responses! Awesome work guys! This is why I’m a part of this forum! So much knowledge to share and not just about our trucks! I agree about the 2005/2006 model year trucks with the efans! That’s a big plus! But I also agree that with the OP’s posted budget, he’s more likely to be finding trucks with 200+ on the odometer. But not a bad thing if ta been well maintained. The good thing is that here in SoCal rust is not a major issue here. Unless it’s lived it’s life parked on the sand, you’re not likely to find a rust on one of these. Hell my truck lived its first 9 years and 74,000 miles of its life in Newport Beach not far from the ocean, and there isn’t a spot of rust on the body or frame!
Steve Waddington
Burbank, CA
All great advice here, that’s why I became a supporting member! I won’t restate what’s already been said, but let me add an observation or two.
This is a great forum for gathering information or trying to figure out, through shared experiences, how to fix an issue. Therefore sometimes it looks like these things have tons of problems. They don’t, it’s just that people don’t post to report when everything’s OK. They only post when they have an issue, or if they are offering advice.
Also, the search function here will lead you to a lot of previously asked and answered questions.
OK, on to the vehicle itself...
I did a BUNCH of research before buying mine, so I knew what I was looking for.
I wanted an 03-06, 2wd, and I wanted all the goodies! I knew how much I had to spend, and I held a little in reserve for tax, title, license, and any immediate repairs. Also, I wanted a local, CA vehicle with car fax and as many records as possible. And I wanted it as clean as possible. Being realistic though, I wasn’t expecting a mint condition 16 year old truck, but a truck that appears to have been well maintained and cared for is probably a good truck.
And I got what I wanted! But I had to look at a couple. Got mine from a listing on Carfax or some online site that was similar. Texting and a couple of phone calls later, we met up and all was good!
Since then, new tires, fuel pump and an alternator and battery, an O2 sensor and a cabin filter retro-fit kit, and I added a rear view camera to assist with parking...and this has been one of the best, fully optioned vehicles I have ever owned!
I got more than what I thought I wanted:
Black 03 LT, 2WD, 5.3 V8, 160k miles, CA car, tags still good for 9 months, all records, Leather interior, heated seats and backrest, adjustable foot controls, memory presets, ez exit assist, removable 3rd row seating, Bose system, dual zone climate control, separate rear a/c, premium ride pkg, tow pkg, sunroof/ moonroof, roof rack, power fold-in mirrors, and more!
That’s a lot of truck for 3400.00!!!!
Woodblocker55
Find a loaded 2006 trust me .. there were alot little things fixed . I'm always into last year of the run .
There's a number of reasons . I would buy 2006 even if needs bit more fixing . 4:10 gears on 5.3 I'm super happy with . Just my 2 cents . But I like all of them back to 2000 . 2003-2005 Cadillac DeVille are sweet also . But that's because North Star had all bugs worked out. But drive one with low miles they are one of the sweetest cars . Serious launch .
Hard to find any good ones left.
Sent from my LGL84VL using Tapatalk
Bigshawn
Mercersburg, PA
Don't know if you already bought one but I would definitely check the brake lines especially if you live in the Salt belt. The rear main seal, transmission I hear alot of people on here complaining about there's but I've never had a problem with mine. The heat/ac front and rear cause the actuators are known to go out.
PrinceTut
