LMC replacement mirrors
95escahoe
Good afternoon, I have a 95 Tahoe and both of my mirrors are pretty banged up (they were that way when I got the truck) and the mirror gears were pretty worn, so I ordered the driver side power mirror and the outer window weatherstripping and installed both the other day, my question is has anyone else used these mirrors before and had any problems? cause the problem I am having is the glass part of the mirror has a shake to it unless the road its smooth its shaking, it stays in the correct position tho, is this just how they are or what? cause my old one wasn't like this at all, thanks for the help
Tbruz
Windham NH
Yup, The aftermarket mirrors shake a bit.
I picked up a set with heat for my 1997, they shook so bad I was getting dizzy looking in the mirrors.
I posted the same question and got the advice to add some foam to contact between the mirror edge and the housing. Seems to have helped a bit but I am searching for OEM mirrors with heat to replace the aftermarket ones.
Tbruz
95escahoe
95escahoe
Tbruz
thanks for the info, it is kinda annoying not gonna lie but I guess it is what it is then
95escahoe
95escahoe
They should not shake at all unless you have some cool music bumping.
That is the only time the old set would shake, its not bad just notice more on the highway or rough roads
---------- Post added at 05:49 PM ---------- Previous post was at 05:48 PM ----------
I have had great luck with street scene power mirrors, no shake.
Might have to look into those in the future if I get sick of it
X-ray Nerd
