Let's see some pics of some lifted and leveled
sarneson91
Alexandria, VA
Anyone ever try to squeeze 305/50r20's on a leveling kit 2.5" front 1" rear? Already have the lift waiting at home just trying to figure out tires, probably gonna go with a set of Mastercraft CXT's. Not sure of the specs on the wheels I have they're not eskey's or denali wheels but I know they're 20x9 and I'm already running 275/55's.
Davy
I just stuffed 295/55r20's on mine with a CCM 2.5/1 kit. I went with a +10 offset wheel to clear the suspension. If your rims are GM, they are likely +31 offset and I think you will rub suspension with 305's. Of course, I had to do some trimming to clear the inner liners for turning.
sarneson91
Alexandria, VA
This is what Im running, I'm out on deployment otherwise I'd be able to check to see what I have. When I bought my hoe this is what was already on it..
Bruizza
You should be okay with that. That is a 32" tire. I have 33s under my truck with a 2.5/1 level and 33x12.5s and have very minimal rubbing and only at full lock. I have factory 22s.
Jbird
Lol, yeah! Might want to get an airbag kit...
Sent from my SM-G950U using Tapatalk
It doesnt squat it any that i can tell. Its just the driveway making it look like it leans more then it does.
vinnyray
Lancaster, PA
I was running 305/50R20s on a 1.5" leveling kit (front only). Slight rub on the rear liner when the rear articulated a lot.
PG01
Up here to the right
sarneson91
Alexandria, VA
^x2 Like the look alot, I'll be sure to post my pictures when I get everything installed. Gonna be a busy week when I get back from deployment, looking forward to installing all these goodies I have waiting for me:)
NGAneer
NWGA
305/55/20 on TGC 2.5 + Bilsteins @ 0.59" and 1" in the rear. Had the same set-up before the Bilsteins. They look short to me now. Next set I'd like 295/60s/
PG01
how do you measure how much it lifted? i had a shop do it
Normally guys do it by fender height, ground up thru center of rim to fender lip. But if you didn’t measure before itll be hard to judge. Easy way is to cut the wheel all the way amd look inder the strut or above strut and there should be a new looking spacer either under it or above depending on what lift/level kit they put on
CamReynolds
they put in new keys. im just worried about my angles
PG01
Haha, you have an nbs. I thought you had an nnbs and was thinking something was off with your avatar....whatever no big deal. If they put new keys then its prob just 2” level....again depending on what they put in. As far as angles, ive seen worse but how does it feel and is it making noise. You can always decrank if it wont rub and uf it makes you feel better
CamReynolds
it was but i got new brake pads, resurfaced the rotors, and got new lower ball joints today so ill let you know it is once i pick it up haha
brice715
