Let's see some pics of some lifted and leveled
63Blackseries
Canada
I am planning to order a 2.5 ccm front and a ebay billet 1.5 spacer for rear and will also be adding bilstein 5100 shocks, would this be a good setup for my non airide Avalanche?
Jonah52
Senor ******
Cleveland
I'd go 2/1, 2.5 will put you closer to your drop stops for your UCA's than you should be. That extra .5" allows for a lot more motion.
63Blackseries
Canada
Ok that sounds good, and I guess I would still be able to fit 295/55r20s with aftermarket 20x9.5 wheels?
Jonah52
Senor ******
Cleveland
Yeah those will be best. And in my experiencing I would sacrifice a little shorter for a little wide. Running a 32x12.50 vs a 33x11, the 295 will look bigger cause it's basically a 12 wide.
Stay around 0 offset as well. Negative with bevyour friend and those tires should be fine if you run positive or 0.
08HoeCD
What's the best way to go for reducing but not entirely eliminating rake on a 2008 LT?
I've read that Rough Country 2" seems to result in Cali Lean sometimes, with front end higher than rear---unacceptable.
1.5" Ready Lift kit?
Jonah52
Senor ******
Cleveland
1.5" spacer.
Just eBay it theyre like $22. A spacer is a spacer.
That should do it.
I am gonna try out dropping the rear of mine 1.5
Alabamakayaking
MadDogDelpho
Texcellent
For a 2 inch level/ lift on my NBS what shocks do y'all think would be best? 5100s? because a couple pages back is sounded like 5100s would be only just long enough, and I'd rather have too long for more travel than not long enough and risk a bad ride.
PuroPinchePedo
I bought it already jacked it has a rough country lift on from what I've seen I think it's a 5" I'm not for sure I'm running a 295/60/20 Nitto and have plenty of Clarence
Nice! I have a 2009 Chevy, white also, and it seems like the 5inch rough country is the way I'm going. That pic is motivation for sure!
brice715
