leaving vehicle with doors locked and engine running
lakerat
Just bought 2023 Yukon Denali. Love it but need to be able to leave my dog in the car with enging running and doors locked while on errands. Best I have found is that it auto shuts off after 15 minutes and that wont work.
Any thougts are greatly appreciated
press and hold start button until it displays automatic shutdown off
thanks much. will try it.
I had to correct that
Showing results for 2021 yukon disable idle shut off
Search instead for 2021 yukon disable idle shutt off
Search Results​
Featured snippet from the web​
Disabling the feature is accomplished by pressing and holding the engine/vehicle start button until the driver information center displays the message “automatic shutdown off.”
https://gmauthority.com/blog/2021/0...ccomplished,message “automatic shutdown off.”
L
lakerat
problem solved and it is easy. when starting the engine, simply hold the start button down for about 10 seconds. Your dash display will show that the shut off is overidden. thanks to all for help
Seamus
Palm Beach
Doing this just extends the time -it will still shutdown. It will NOT stay running. GM acknowledged some people need to keep it running and you can buy the program and have installed at the dealer that will disable it altogether. I cant remember its either 30 or 60 minutes then it will shutoff when doing the hold key thing? We had the same issue on vacation with our dog in a 2021 suburban. Every cycle had to hold start button, but it gave us alittle more time when stopping in a restaurant. We still set the timer on our cell phone to alert us to go check the truck. I am considering the program for my currect truck, as it defeats the time out completely.
I believe that I am free of this automatic shutoff on my 07, and I'm glad, as I often leave the truck running in the summer when when I'm shopping and my dog is in the truck
not entirely true, it is noted that this does not work on all vehicles. On the ones it does work on it will continue to idle until out of gas.
only if you leave the key in the ignition, otherwise it's 10 minutes and it can be cycled twice without inserting the key again.
Yes, I do leave my key in the ignition while I am away. I'm not concerned, as my 95 lb. White German Shepherd believes that he owns the truck, and it would be a sad day for any person who opened any of the truck's doors with bad intentions.
Seamus
Palm Beach
Unless something changed on the 2023...it will time out, just a bit longer if you do this procedure. I have done this on the '21 and it gets extended but will shutoff. I have seen the TSB for the programming if you choose and its at the customers expense and liability. It defeats the shutoff entirely as you describe, but has to be programmed.
Seamus
Palm Beach
This was a safety feature, maybe something changed in new model
Seamus
Palm Beach
Let us know if the 2023 times out after 60 minutes like previous years. havent done it in a while in my '21 but I think it extends you from 30 minutes to 60 minutes then shuts down. I wouldnt want anything to happen to your dog, thinking it will run till out of gas. For that there is the above TSb you can buy the programming.
you can idle for a very long time on a tank of gas more than 24 hours on a full tank
Seamus
Palm Beach
Yeah, but not on a 2021 unless you buy the program to disable the time out. The hold the start button only gets you 30 more minutes. So your dog will be dead in the summer if you left him for an extended time thinking you get a tank of gas amount of time....you don't. It has to be disabled at the dealer at your expense. My experience is only with a 2021. So are you saying Gm did away with this safety feature on 2022-2023? and wont time out?? The TSB does only state 2021.
it just says it doesn't work on all vehicles, there is supposed to be a way to put the vehicle in service mode but when I search for it all I find is putting the transmission in neutral
vtxtexan
