Key Fob Range
jakcol997
Has anyone figured out a way to amplify the range on the key fobs? I have to be like 2 feet away from my car to get it to unlock.
Big Mama
Virginia
Or might be time for new outer shell? Mine works from inside the house or about 100 ft
My fob works for remote starting when I'm in the house, and my truck is 75+ feet away, within its own shelter. In the parking lot, say at Home Depot, my remote starts the truck while I am still in the store, and the truck is parked 100+ feet away in the parking lot.
If you've replaced the battery, and you still have to be within 10 feet of your truck for it to work, I suggest that you consider replacing the fob.
rjr
How about your 2nd fob? If that has short range too, it wouldn't be a fob issue. I don't see the fob shell as having any effect.
petethepug
Michael
SoCal
This is an issue with other Non GM vehicles too. Our 08 will transmit 500+ Ft no issues. I would research how to extend the range to see what the receiver uses for it’s antenna.
I’m not sure what GM uses to pull in the key fob signal. Our VAG cars are venerable to rain on the GSM antenna connection that renders the remotes to chin use only.
Big Mama
Virginia
I recall my old fob doing something similar so I got one from Amazon and programmed myself it works much better than either of the 2 original fobs. @NathanJax got the fob that looks like the new rigs. Nate how far does yours work?
NathanJax
Vacation Nathan
Jax, Fl
Far. I'm not sure how far, but if I can see my truck or hear the horn, it'll work.
JDvorak85
I have a fleet of 2017 and newer Gmc and Silverado 2500 trucks and the range is pheonominal with the key fob. Bought the wife a 2019 Tahoe last year and the range sucks! Literally have to be within 15ft of it with the wind blowing the correct direction for the fob to work. It has been like this since we rolled it off the lot
johnsonwillie199
