Key Fob programming - 2014 Tahoe
madmanjustice
In the past, I had a 2013 Tahoe PPV. I bought extra keyfobs for it and was able to program them myself using the button for the trip meter since the PPV did not come with the DIC.
Now I have a 2014 LT with the DIC. I have a working key fob, but the area on it where the keyring goes through is broken so I cant put it on a key ring. Is it still possible to self program fobs for 2014s. I would find it strange that I could do a 2013 and not a 2014.
If worst comes to worst, i guess i could transplant the insides of my current fob into a new housing.
mikez71
I had no idea there was a way to do it program fobs with the tripmeter!
I don't think it's in the DIC options, so I would try the same method you did before.
If you swap cases, the dorman case is not as good as OEM, definately stick with OEM.
madmanjustice
madmanjustice
i have been doing some digging for info, it looks like the ability to self program fobs was removed for 2011 and up, but some vehicles that were "fleet" vehicles still had it. Which would explain how I was able to program the fobs for the 2013 since it was a PPV and was probably considered Fleet.
I'll need to check the menus in the 2014, but will probably need to purchase an external programmer like I did with my 2019 Grand Caravan
mikez71
btdieselworks autosync will do it. I used one to program my 2012.
It's a great device that has lots of other features.
Moderator
People's Republic of Colorado
Just ordered a fob and spare batt from Northcoast...
PG01, Thanks for the link.
Free Tip Sunday:
If you want to "tag" a member, either quote that member's post (like I did here) or start with a "@" sign and start typing the member's username and select it from the dropdown, like this: @PG01
If neither is done, your post may go unseen by the desired member.
PG01
Up here to the right
Free Tip Sunday:
I seen it…. Screw everyone else….. lol
