Key Fob Problem with drivers door only
scrap
RE: 2018 Premier:
With key fob in pocket, drivers door requires many many tries to lock or unlock. Fresh battery in fob. Other three doors work instantly. All doors work instantly when pushing the button on the fob. Tried it without my cell phone in my pocket. (My cell phone interferes with the remote on my TV if my phone is near the TV)
Fless
Moderator
People's Republic of Colorado
RE: 2018 Premier:
Are you using the FOB all the time, or are you saying that the door panel switch doesn't operate correctly when you have the FOB in your pocket (not using the FOB to unlock)?
Bob2C
Northern VA
RE: 2018 Premier:
Have the same problem. Doesn’t happen every time. 2018 Tahoe. Frustrating after spending 50k +
sealandsky
Minneapolis, MN
RE: 2018 Premier:
I'm also experiencing this issue and in my case it comes and goes week to week. For me it's the drivers door and the tailgate. There is a service bulletin that addresses the issue: https://static.oemdtc.com/TSB/MC-10156932-9999.pdf
(Credit to swathdiver)
S
scrap
I use the door panel switch with the FOB in my pocket. I don't use the button on the FOB. I keep pressing the door panel switch over and over till it unlocks. This is only on the drivers door. Sometimes it works on the firs try, but not very often.
JasonW4141
