Keeping Transmission pan cooler
2011.....always wondering if there has been a software update for the tcm to make it shift better...I bought this Tahoe 1 year ago, so I don't know if it has ever had any tcm updates. Has anyone here had updates done for the 6l80 tcm? If so, was it worth it, and what benefits did it do?
Yes, it was tuned by BlackBear and shifts great! That's one of the best parts of having the tune done. When was your fluid changed last?
As for benefits, well, from a roll if you stomp on it and it shifts back down to first, lifts the nose off the ground and the truck plumb takes off! The shifts are more firm when on the throttle and the truck is more efficient generally, even with AFM de-activated.
I carry a lot of weight in my truck at times but have not towed with it yet. Am well pleased with my transmission temperatures with clean fluid and the stock system. I think it's around page 27-30 in the post Useless Information where operating information was posted about the 6L80 and the temps mine runs under various scenarios.
thompsoj22
california native "REPUBLICAN" high desert
a transmission oil cooler and deep transmission pan will help keep the transmission temps down, I have both on mine and regular driving for me (speeding for you) then my temps are usually in the 140's range, so if you drive like a normal person it may bring it down to 120's-130's depending on your elevation
Just a question in regard to the deeper pan, The space between the trans pan/ exhaust crossover is allready tight. Is the deeper pan still recessed to allow for this clearance issue or the same depth throughout? i want to install one simply for the drainplug and future servicing but questioned the fit. Oops, i see the pic but i dont feel i have the much clearance currently, The pic is a 6L80 on a 6.2?
PG01
Up here to the right
No 5.3, but nonetheless, its only deeper on the one side, not the exhaust side. Fyi 6.2 and 5.3 bolt up same to 6 soeed trans. Basically they are same motor,
kbuskill
NE. FL.
This is the 6L80 deep pan...
https://www.yourcovers.com/transpan_9427.php
The other one I posted was for the 4L60 4 speed.
I bought the b&m pan for mine, the exhaust had to be lowered a inch or two to get it on but it does not rub or anything it was just while getting it installed
kbuskill
NE. FL.
Derale also makes one that has cooling tubes in the bottom of it.
https://derale.com/products/transmission-pans/cooling-pans/14204-detail
Pretty cool idea... unfortunately from looking at the stock deep pan height, and comparing it to this one, it will definitely not fit with the exhaust crossover pipe in the factory location.
I bought that one and it looked like it wouldn’t fit with my headers so I sold it to a member. After that I ended up buying my Performabuilt and it has a warranty that I don’t want to void. They use a stock deep pan and also provide a heavy duty cooler but I run the Tru Cool. I figure if a performance trans builder specs a stock deep pan, it should be good.
Nyc2011Denali
