Just Fishing's 09 Tahoe Build thread
Just Fishing
Just Fishing
Can't fix stupid
Utah
Depending on my motivation, I'm thinking I want to also pull the engine and change the cam bearings due to warnings of those OEM bearings having issues with the dual valve spring (pac) setup I have.
It would also be easier to setup the pushrod legnth with the new lifers.
The new style should require less preload with these heavy springs I'm running. ;)
That would also allow me to really check everything out.
But we shall see how motivated I get with that. :jester:
Just Fishing
Just Fishing
Can't fix stupid
Utah
Also, the transmission has been going great!
I even lowered the pressures in the transmission to see how it does with a more "oem" pressures.
So far so good!
I still haven't pulled the pan yet, so I'm trying to hold off from patting myself on the back.
however, I bought a tool to hopefully make sucking the fluid out before pain removal easier for me.
I have been watching this tool for some time.
It has been over $100 for a while.
I saw it with a price tag of $69, so I decided to grab it.
I haven't had any issues with the "OEM tools" brand, and as of right now I consider it to be trusted like "Astro"
There are other brands like 4 uncles that are much cheaper, but I haven't had the best experience with their stuff.
Since it's plastic, I'm willing to spend a little more for a brand I trust....
This runs with either a manual pump or using an air compressor.
I fully plan to air compressor it. :cool:
After I ordered, I'm now thinking I probably should have gone with the larger capacity model just in case the pan holds more fluid than I think it might.
I fully plan to shove the tube down the dip stick hole and walk away for a while... :jester:
There are a few things that I don't like too much about the design, but we shall see how it works out.
I also already see that I'll need to add some hose extensions.
but that's easy enough to do by either using fittings, or just sticking a smaller diameter hose in the current hose. :angels2:
Just Fishing
Just Fishing
Can't fix stupid
Utah
and next, the transmission cooler setup I did.
Running in parallel with the radiator @ stock cooler sitting on their own circuit.
then flowing from and to -8an (1/2in) vs the stock -6an (3/8in) lines.
Pressures still going great, never goes over 70psi on the cooler circuit.
And so far, I haven't used the bypass valve I setup to shut off flow from the large cooler.
An old "install" picture for reference.
I have the OEM cooler sitting on front of the larger double pass cooler in the image.
Right now I just shoved a piece of cardboard down through the access hole in front of the hood latch.
That seems to be the perfect size to shove something in there in order to limit airflow.
That's allowing me to get the transmission temperature to a nice low 170 degrees after a few hours of use around town.
I'll play around with the idea later, maybe even make something a little more permanent, but I like this vs possibly increasing the back pressure in the cooler lines.
Sparksalot
Bastrop County, Texas
So far so good!
I have a pump like this to do the same.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Just Fishing
Just Fishing
Can't fix stupid
Utah
I also had an issue where I started seeing codes related to running too lean during cold startup once winter hit.
I started doing some adjusting on my MAF to see if i could sort it, but it continued. :confused:
AFR gauge showed it idling pretty lean, but it bounced around a bit.
I finally found that one of my recycled hoses that connects my catch cans to the intake split and started leaking, causing the issue due to a vacuume leak.
:lol2:
During that, I found that I had issues opening the MAF scale.
And clicking around, I found that the newest hptuners version has a new "Feature" where some emission related settings are now locked.
To get them unlocked, you need to go to the hp tuners website and take a little online class.
Afterwards you can grant access from the site?! :think:
Reverting to an earlier version would remove that restriction, however it's just a warning for others.
If you need access to the O2 sensor settings, don't update unless you're ready to take the little online course. :happy160:
And for that newest version, they added some tools related to logging and the special functions has a few new features.
Nothing really warranting the update IMO, but it's there.
I'm sure this is to prevent hptuners from getting fined/shut down. ;)
And of course, the issue I was having wasn't even related to that, for some reason the laptop that I use to program won't open that value...
It will open others, just not that one. :crazy:
Just Fishing
Just Fishing
Can't fix stupid
Utah
I used this yesterday to suck out the transmission fluid.
I didn't have much luck with the hoses that come with it.
Instead, I used my 6mm air line that I used for the other fluid pump and adapted it to the hose that it came with.
That allowed me to get further down into the pan.
Example of what I'm talking about with the air line/hose: https://www.amazon.com/s?k=6mm+airline+tubing&ref=nb_sb_ss_fb_1_7
I have a couple pneumatic air cylinders that I played around with for a while.
I never found a really cool/good use for them around the garage, but I came up with plenty of ideas. :jester:
Cool stuff with the different ways you can direct air using the little controllers they sell (cheap).
If you ever played with lego's as a kid and had the pneumatic technic lego sets, it's like that but bigger!
I made an adapter out of some hose I had laying around, and then sealed up with some electrical tape for good measure. :hahano:
I ended up drilling out the little air outlet in the fluid suction tool, that gave me much better suction!
I didn't go much larger, just a tiny bit.
then beveled the outlet to quiet it down a little. :jester:
I'm happy, it sucked with plenty of power.
And the size of the tool was just about perfect for the amount of transmission fluid I pulled out.
I should have spent a little more for the larger size, but I didn't make a mess. :cool:
Just Fishing
Just Fishing
Can't fix stupid
Utah
I also noticed some "lines" in the fluid i extracted, but I didn't really have any clutch material or too much metal on the magnets in the pan.
Just the right amount for the new transmission.
I think the "lines" in the fluid came from all of the transgel I used during assembly.
(Just about an entire tub) :jester:
I really coated all of the seals to prevent any sort of tearing during assembly, so much I had to force in transmission fluid in order to pass the air checks before installing the valve body. :patriot:
I figure the extra transgel probably helped thicken the fluid up just enough to help with the break in of the new bushings.
Enough I figured I didn't want to tow much until I did the final fluid change.
I think I'll use my cooler line filter housing to help me flush a good gallon or two through the cooler lines.. :Jedi:
Filter off and I have a good drain port. ;)
Just Fishing
Just Fishing
Can't fix stupid
Utah
I haven't updated this in some time.
The Tahoe is doing well with the 6.0 and the transmission.
I still want to replace the lifters one day, but it's good enough for now.
The Tahoe really moves with the new setup!
I have been running some "cheap" 15w40 oil, that resolved some of the lifter noise and the engine has been happy since.
Driving around town it's still a light touch and it moves.
I'm still running the 5.3 timing, mostly out of lazy.
I did adust the MAF for a little extra fueling, and it's happy there per the wideband.
I still need to spend the time to really dial it in, and I'm still dreaming of the 6.2 timing for long term.
In the end of 2023, I picked up a new to me boat, and the Tahoe did fantastic hauling it home for its several hour drive, and up some canyon roads at highway speeds. :ehcapt:
The boat is a 1994 22ft StarCraft Islander 221 with a MerCruiser 4.3l that has a somewhat small crack in the engine block.
The trailer is a 05 Metalcraft with all the bells and whistles, first time having something with brakes and double axles!
Not to mention this thing was professionally fitted to the boat as metalcraft is local.
The PO kept meticulous records, I have everything including the trailer and the fitting done by metalcraft.
Work starts on it soon... :ehcapt:
Then the end of 2022 I also picked up a new project, the price was right so I couldn't pass it up.
The Tahoe got it's first taste of about 7,000 lbs (+/-), it did great!
The project was a 2007 Jeep wrangler Unlimited.
Price was 5k.
the catch: Severe rod knock/spun bearing.
I think part of the good deal and the motivation is that the seller came from NC, and the Jeep still had the NC plates on it.
He tried and failed to get it registered here in UT per some receipts I found.
I found it was leaking oil, and antifreeze pretty badly, I suspect that helped make the engine fail.
It was a pleasure to work on something other than the Tahoe.
I ended up rebuilding that engine for under 1k invested.
I had to replace one rod + piston, and I got a used crankshaft from a minivan that was a perfect match.
Metal had gone everywhere, so it was a full gut, cleaning, new camshaft, new lifters since they were seized with metal. :jester:
Pushrods had that sanded look, so those were toast.
This engine has about 4k+ on it now and it's doing great. :cool:
One fun part was that Chrysler made the cam bearing setup so it's impossible to replace like you would an LS.
they have to be installed from the front back, no way to insert cam bearings through the bottom...
I hired that job out to the best person I could think of, and it was still a challenge!
The hardest one was the front since you can't use the other holes to align while it's driven in.
So the front bearing was a bit tight for the new camshaft.
He had fitted using the old camshaft, but the size difference was enough that I couldn't fully install the cam shaft!
Some careful fitting and lapping of that bearing on my end, I used car polish/scratch remover as a super fine lapping compound, it also showed me where the high spots were.
finished with some non-wax car polish (nu finish), then brake clean to remove any residue, but the fitment was still pretty tight. :banghead:
Once she was back together, I had to deal with some wiring issues, and I found some history of it failing emissions due to some O2 sensor issues.
Later I began the "build" as things showed up second hand, and for the "get it out of my garage" price.
First I needed to dump the tiny little tires it came with, those were 29in tall and on 16in wheels.
Per the sticker in the door it should be on 18's and 31in tall.
One day while shopping I found some nice take off tires, mounted on wheels for $200.
A picture my wife snapped while it was still up in the air, if you look closely, you should be able to make out the jack handle, and the rear tire is above the driveway by about 2inches. :deal:
The tube doors were also picked up as I had to do some body work on the rear tail light.
The wife came out to see it with the top removed, sat in there and said with a sad look "I thought it would be more open".
And she didn't like the idea of no doors, so tube doors it was!!
Just Fishing
Just Fishing
Can't fix stupid
Utah
another "Feature" of this jeep was an absolutely trashed interior.
If I were to guess, the top was off or the windows down.
And some birds had a party.
The carpet and drain plugs were also missing.
A bit of gear oil had also spilled in the back, so it had that wonderful smell...
Once she was running, I took a black trash bag with me and headed down to the local wash bay.
This was in February, so freezing was a real thing.
I soaped this thing inside and out, and even used the brush where I could. :emotions33:
the seat's cleaned up pretty well, and I got the white shit that was all over the doors, dash, seats, and floors off.
After I bought this thing i had already picked up some nice diver down seat covers that were on an "after christmas" sale.
And I scored a full bedrug carpet kit that was a return.
More than 50% off, but there was some minor damage on some of the pieces.
Just Fishing
Just Fishing
Can't fix stupid
Utah
I also needed to replace the front bumper as it wasn't straight.
I ended up scoring a really nice winch bumper second hand, but new in box.
Quadratec brand.
Under $200!!
then I had to fill the big empty hole with something, so a winch found it's way via amazon.
Xbull brand with a 12,000lb capacity, then another $20 for a warn sticker kit since it seemed like it was asking for it.
Empty hole that was begging to be filled.
Installed with the x-bull stickers still there.
Increased the value of that winch by at least $1,000!!
From here we proceeded to enjoy the Jeep over the summer.
My neighbor has a 30k side by side, I think this is much better + I can drive on the freeway!
A picture from my piece of worthless desert!
Just Fishing
Just Fishing
Can't fix stupid
Utah
also forgot to mention the infamous Jeep death wobble.
This jeep had it bad.
Cause was both track bar mounts had become egged out.
Allowing the front axle to do the crazy wobble feature.
Luckily, I have someone that was able to fix it for a couple hundred bucks.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Then at the end of september of 23, right before fall and before the wife and I could get out to enjoy the fall leaves in the Jeep.
and a Day before I was headed out to pick up the islander!
The wife told me "maybe this is a sign to not get the boat"
Of course, my logical answer: "well then the Tahoe would have gotten hit!" :jester:
A neighbor decided to do a wreckless turn right in the side of the jeep.
Tweaked the suspension, flattened one of those cheap tires, ripped the fenders off, and put a big gouge down the passenger side of the Jeep.
The Jeep tore right through the front of his Tacoma 4x4, ripped the ball joints and tie rods off, and sent his headlights and front bumper cover skidding down the road.
The Jeep drove home once I swapped out to the spare tire.
I spent probably $800 out of pocket fixing the suspension and replacing the antenna mount, and I got paid 4k for the damage.
The wife and I decided to live with the damage, so a bunch of debt was taken care of out of that.
I spent much of the fall/winter looking for parts to get the Jeep back on the road.
Part of the problem was the tires.
I refuse to buy the stock size since I have plans, but as luck would have it I found a set of 35x12:50 R17's mounted on Jeep wheels.
Scored them for $70!
Not the best tires, 6 years old and Patriot tires wasn't known to be a great tire.
But cheap, and they have fun little punisher skulls in the tread pattern!
Also no signs of any dry rot..
About a week later I picked up a 2.5in lift kit, new in box for less than $400 (iirc).
Then I picked up a set of Teraflex adjustable control arms for $200 to give me a little extra adjustability.
As she sit's lifted and with the bigger tires.
:head3:
Still to come, I have a front axle truss to install, and I need to change the gearing.
Currently it has 4.10's, I'm planning to go with 5.13 since this is an even more gutless pig now. :jester:
Just Fishing
Just Fishing
Can't fix stupid
Utah
I almost forgot about the body damage in the rear.
When I bought this the driver side tailight had been pushed in, a common thing.
The challenging part was the body lines were pretty much gone.
the paint was also pealing from the damage, and some surface rust had already started.
So that needed to be fixed, so the top came off and work began with a harbor freight stud welder/dent puller.
Lots of work went into this until I was pretty happy,
I got it really close, and then a skim coat of body filler to help smooth it out.
I don't seem to have a before or a finished picture that was pre paint, but this is how it looked as I prepped it to sit outside this winter.
I used black spray paint since that's what I had, and I needed to cover the primer...
Body lines look better with the taillight removed, but they weren't perfect.
Just Fishing
Just Fishing
Can't fix stupid
Utah
For the Jeep, I also have two soft tops.
The first one that I ran over the summer, slant back and the top worked out to be a really solid "bikini top"
This is the only picture I have on my computer with it, full sides on.
I think it will look better with the bigger tires, but it wasn't bad.
Most of the summer I had just the top and doors on, it gave it that "truck bed back" look that I loved.
With the doors on it was good enough for the AC to keep the front seat's nice and comfortable, even when it was over 100f.
Over the winter I picked up the OEM soft top, and it's the one that folds back like a convertible.
Hopefully I'll get to test fit it here soon.
All in price at this point.
Including the original purchase price, engine rebuilt, parts, and accessories, and minus the $4k that I view as a "Refund".
I'm at $5k total invested.
Probably add a few K to that price once I'm completely done.
I still need to buy gearing, probably front and rear air lockers, and a new set of BFG AT (KO2 or KO3).
Front and rear lockers are 1k each, gearing is about $700
Tires are about $1500.
:violin2:
Just Fishing
Just Fishing
Can't fix stupid
Utah
Anyways, I'm pacing myself with $$ for right now.
While I really want the jeep back and running at 100%, I also have that boat that has a little higher priority right now.
My in-laws are already making plans for it this summer, so it gets resolved first.
I'm kind of leaning towards paying the boat loan off first, and then doing the Jeep.
Or I just do gearing and skip the diff lockers for now. :chair:
But that seems silly since I need to do gearing anyways.
Damn adulting.
:yaoface2:
Just Fishing
Just Fishing
Can't fix stupid
Utah
Well, I have had a nice break from working on the Tahoe.
The Tahoe is still doing great, over the summer it spent lots of time towing a 22ft StarCraft islander.
That Starcraft Islander (Model 221v) is a 1994 model, it was also a bit of a project spring of 24, and into early summer.
Finished mid-July.
I bought it with a cracked engine block, and needing some flooring work.
The boat itself is aluminum, and the "V" prefix in the model specifies it has the heavy-duty hull.
Reinforced big time and meant for "big water".
For the engine replacement, I ended up buying a built engine, and then doing a full tear down of that engine.
I found it was dirty as fk, lazy builder.
Lots of little issues found with it, including a freeze plug that they left inside of the block, I had to pull the freeze plug, and then remove the old one from within the block. :mad:
Turning the assy I found grit, that lead to the full tear down, plus how dirty everything was made me want to verify everything.
The grit sound was caused by one messed up thrust bearing, I guess they used a generic and then clearanced the bearing using a brick?!
Yeah, so it got full bearings, and I ended up replacing the balance shaft bearings.
Dirty as fk, plus I wanted to clean behind them.
To do the swap, I didn't have anything tall enough to pull the engine, so I opted to make something using UniStrut.
This is tied to the studs in the wall, and the ceiling, and then an extra support towards the middle for good luck.
They also did the hot wash tank, but didn't follow up with brushes and fine cleaning. :rolleyes:
The flooring is just plywood, and the hull is 100% aluminum, including the "Stringers".
The flooring while it's Marine ply, was originally "Sealed" with vinyl flooring.
The PO decided he wanted carpet and cut the vinyl out and had it carpeted.
That resulted with the carpet holding water against that marine ply.
The first thing I did was to rip that carpet out, and put the original vinyl back in.
Somewhere I have a good before picture, but I wasn't about taking pictures of how nasty it looked with the "Bathroom carpet" look. :violin2:
This is a picture during, I had tp pull up the benches, and then flowed epoxy into fhe plywood in order to attempt to "bring it back".
I really should have just pulled all of the plywood up, however I was on a time crunch.
End of july the family had a big outing where they wanted the boat up at the lake.
It took so much epoxy and sanding to really bring the floors back to something I was willing to cover with $600 of vinyl flooring, It might have been faster and cheaper to start fresh. :happy175:
I did end up having to replace the center floor section.
The way the boat works, the side flooring has a complex box/cross supports that go from the bottom of the hull up to the floors.
Lots of support there.
The middle flooring section is where the 53 gallon tank sits.
Not much support, it's also a thicker piece of plywood at 3/4in.
there was no bringing back that middle section where I would ever be happy with it.
So a new piece was made and encapsulated in marine epoxy.
And then painted white using an epoxy paint for extra protection.
I don't have a good picture of that sitting in my amazon account.
The Jeep project also stands as "done"
Final thing was a front and rear axle re gear to 5.13 and some Eaton true trac diffs installed in both axles.
I was pushing for air lockers, but the guy doing the work talked me out of air lockers.
He does a bit of rock crawling and sports a Jeep JKU like mine but sports a 6.2ls (Gen 4) and 6l80 swap. :p
Told me to run them, and when I get to the point where I want to upgrade, he told me to also replace the front axle.
As it sits now, with a fresh set of BFG AT KO2's and wearing the OEM soft top.
Just Fishing
Just Fishing
Can't fix stupid
Utah
More on the boat (ran out of room for pictures!)
This is a picture of the boat as it currently sits,
And this is on the water while we enjoyed the boat.
Security camera view, I installed some faux teak under the windshield/dash.
originally it was this blue astroturf stuff, the PO installed carpet right over the top of that. o_O
I wanted to pull the carpet from the sides of the boat, up by the driver and passenger seats, but that would end up being a whole nother thing.
And adding more time to a project that needed to be on the water.
So, it's a later problem. :ehcapt:
For now, the boat works! :angels2:
The engine cover was another thing,
The bottom of the engine cover is aluminum.
Orignally covered with the same vinyl flooring on the alumium parts.
The top is ply.
Covered with that blue astro turf, then the po put thick carpet over the top of that.
It held water, it was mostly done.
I was able to rebuild it, but I had to do lots of trial and error to get the angles right.
He also removed some of the supports for the top as it's a clamshell with a hinge, that caused some warpage.
I used a few pieces, but I had to replace 80% of the wood.
I still need to either paint or cover with vinyl.
I have the aluminum parts painted with the correct primer, and then the top is a different color/type of primer, I still need to do some fiberglass work to really clean it up.
I'm leaning towards finishing the top with an epoxy tractor paint in paper white.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Wife snapped a picture of this, fam enjoying the boat.
I love the swim platform, first boat that ever had a big one.
And it helped that it was a hot summer, i found myself not able to resist jumping into the 79-degree water.
Just Fishing
Just Fishing
Can't fix stupid
Utah
I also bought some accessories for the boat, I haven't had a chance to use them.
It seemed that it kept raining every weekend, and then suddenly it was Fall and time to go fishing. :violin2:
Lots of fish caught, none kept.
The boat has a livewell, it worked great to keep and purge a buch of crayfish.
Too many really.
Otherwise, the LiveWell makes a fantastic urinal!!
X-ray Nerd
