IPCW Platinum Smoke tail install notes
dheadv8q
Oviedo FL
I installed these today on my late production 07. The instruction states that if installing on a post May 06 production date, to use the adaptor plugs. When I did, the turn signals didn't work. Troubleshooting revealed that my wiring (production date 5/17/07) was a combination setup. The 'upper' bulb plug uses the adaptor and the 'lower' bulb uses the Tahoe plug. The 'upper' plug operates the inner vertical LED strip, and the 'lower' plug operates the outer strip. I was surprised that only the inner vertical strip illuminates for braking.
Both are lit for running, and the outer blinks for turn/hazard. I verified this with their Tech help line.
I expect I will add one of the flexible Oznium LED light strips noted in the smoked tail thread.
macky
post up some pics, ive been thinking about getting the same lights
dheadv8q
dheadv8q
Oviedo FL
Its a rainy night, but here you go
macky
thanks, looks good. i was considering the ones with the amber led for turn signals. your pics may seal the deal. any fast blinking.
dheadv8q
dheadv8q
Oviedo FL
I had fast blinking when I followed the directions. Then I did it right. The directions were wrong for my truck.
dheadv8q
dheadv8q
Oviedo FL
When I spoke with the guy at IPCW he was apologetic, and said it was really hard for them to figure out what GM is doing year over year...
Timmay
Pingree Grove, IL
I have the smoke IPCW tails and for the money I paid I'm not really impressed with them lately. I drove behind my truck today and they're not as bright as I was hoping. Definitely not as bright as other LED's I've seen on other tails. So I started looking into eBay today and found these: http://cgi.ebay.com/ebaymotors/2007...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Anyone else seen these or have them installed? The picture works out well for me because I have a white Denali so I like the way they look. I also like the 3 rows of LED's rather than the 2 on the IPCW. Problem is you can never tell how bright they are in a picture. So I'm hoping someone here has them or has seen them and could possibly compare them to the IPCW for me.
Thanks.
Modded
That Guy
Timmay. a couple of us on here have those tails, not in that color though. I say get them, just not those ones because they are kind of ugly. Get the black model instead so it matches stock Denali tails.
Timmay
Pingree Grove, IL
I see red/clear and red/smoke on 'bay, that's it. Can you give me a link for the black ones you're referring to? I have the smoke IPCW's on now and think they're a nice touch so that's why I was going to stick with the smoke on the new ones, but if there are better ones out there I want to get those.
Timmay
Pingree Grove, IL
Thanks for the info Modded. Have you seen the IPCW's during the day? Compared to these are these brighter than the IPCW's? Night time is a different story, everything is bright then. I want something that really stands out during the daytime. Thanks again!
Modded
That Guy
Yeah I have seen the IPCW because I had them, not only are the above G3 LEDs brighter, they simply look better to me. The only IPCW lights that look good are the black ones (I had) or the ruby red ones, the others are abit nasty looking.
If I was you, I would get the Black or Red IPCWs, or the G3s above in red.
Here is an old pic of mine.
Timmay
Pingree Grove, IL
On the link above that you gave me are you suggesting picture number 3? I see the red ones in picture number 1 but not sure how those would look on a white truck. Thanks again, sorry about all the ???'s.
brice715
