Intermittent rear wiper problem 08 Yukon
alstonsailor
the rear wiper will work once on both setting, then stop but not stow until switch turned off. Please help
wjburken
Eastern Iowa
Welcome to the group. There a bunch of smart folks on here. Unfortunately, I have no experience with this type of problem.
my first guess would be a bad motor, you could confirm with a tech2, if you don't have access to a tech2 a shop is going to charge you anywhere from $80-110 to diagnose the problem, a new wiper motor is about $150. you may get lucky and get a shop/dealer to apply the diagnostic fee to the repair which would include extra labor for removing the rear plastic trim on the rear hatch to get access the motor, you could save some money and take the plastic cover off your self to access the motor,
if you want to test the motor yourself, this the procedure to test the motor for functionality, if the motor works during the test then the front multiswitch may be defective instead
A
alstonsailor
The motor could be bad even though the wiper cycles once then stops on either intermittent or continuous? Also the wiper arm doesn’t stow itself until I turn the switch off.
if you test the motor yourself and find it defective this is the procedure to replace it
1. power rear wiper arm to middle of the window position, the remove the nut cap and nut, remove arm and clean the knurls
2. after that refer to the picture I have uploaded
3.
Rear Window Wiper Arm Assembly
Procedure
1. Electrically PARK the rear wiper motor.
2. Place the arm onto the pivot shaft while holding the wiper arm
tab firmly into the park ramp pocket.
3. Secure the nut.
4. Perform a wet wipe and inspect for return to parked position
A
alstonsailor
3.
Procedure
3. Secure the nut.
Any chance it’s the relay since the wiper works once on both settings? Or is it the switch. It just seems odd it will work once on both settings and then stop.
I think electrically testing the rear motor if you do not have access to a tech2 is going to be the easiest way to find out for sure, the motor should operate continuously as long as there is voltage applied, it wouldn't just go once and stop unless it was loosing voltage somehow (or the motor or control module was bad) which you could test at the harness
this is why I said it would be easier to test the motor first just to rule it out, lol
Rear Wiper Motor Circuit Test
1. Ignition OFF, disconnect the harness connector at the rear window wiper motor.
2. Test for less than 1.0 ohm between the ground circuit terminal D and ground.
 If greater than the specified range, test the ground circuit for an open/high resistance.
3. Verify that a test lamp illuminates between the B+ circuit terminal E and ground.
 If the test lamp does not illuminate, test the B+ circuit for an open/high resistance or short to
ground.
4. Ignition ON, test for B+ at the signal circuit terminal A while the rear window wiper switch is in the
delay and on switch positions.
 If B+ is not present, test the signal circuit for an open/high resistance or short to ground. If the
circuit tests normal replace the turn signal multifunction switch.
5. If all circuits test normal replace the rear window wiper motor.
Component Testing
Rear Window Wiper Switch
1. Ignition OFF, disconnect the X4 harness connector at the turn signal multifunction switch.
2. Rear wiper switch OFF, test for infinite resistance between the ignition terminal 1 and the signal terminal
2.
 If not the specified value, replace the turn signal multifunction switch.
3. Rear wiper switch in the ON position, test for 900-1.5K ohms between the ignition terminal 1 and the
signal terminal 2.
If not within the specified range, replace the turn signal multifunction switch.
4. With the rear wiper switch in the DELAY position, test for 2000-2400 ohms between the ignition
terminal 1 and the signal terminal 2.
 If not within the specified range, replace the turn signal multifunction switch.
Where is the module? Is it a relay?
I believe the module is part of the rear motor assembly
also just a side note, if your vehicle is "rain sense" equipped the issue you are having could be related because the wiper will only wipe once unless rain is detected, so to test that if you have rain sense pour water over the front window view rear mirror area which is where the rain sense sensor is located and see if the wiper activates like it should.
wjburken
Eastern Iowa
I was not aware that the rain sensing function had any impact on the rear wiper. Thought it only controlled the windshield.
it might not control the rear wiper but it would be easy to find out by just running a water hose over the front window, and that may only apply if the wipers were in delay mode
wjburken
Eastern Iowa
Very true. Wasn’t discounting your troubleshooting methods. Thought I learned something about my last vehicles that I didn’t know about.
Continue with your course on troubleshooting.
it was just a Note in the service manual, but looks like it would only apply if the wipers were in delay mode
Escalade2007
